I guess the power circuitry isn't up to it so nvidia disabled overclocking. I cant think of any other reason why they'd want to disable overclocking on their fastest mobile part
huh? power circuitry is outside of the chip and from the IHV - if they put 16 power phases and water cooling it would still be disabled.
This is mawell their most power efficient chip to date, power delivery is not the issue here.
We all know how good kepler/maxwell is at controlling/monitoring power usage and temps.
I think I've read Kaap say that 4x980s can produce some heat though so 2x980M sandwiched in a tight space might not keep the same standard for cooling as SLI 980s in a desktop case.
even 1 x 980m is barred from overclocking
btw this has been in the drivers for 2 older versions as well - since lat year
980m is an enthusiast class GPU, it ships in expensive gaming laptops that should be engineered to cope with excess heat and high power draw hence Asus advertising their 980m laptops as overclockable.
I think we are pass the point of giving the Nvidia the benefit of the doubt.
If I had to guess, I'd say their major OEM's have requested it after getting sick and tired of replacing GPU's fried by idiots not realising that mobile parts are under extreme thermal and power constraints.
Anyone who knows what they are doing would just OC from the BIOS surely? Maybe better that some people are not able to OC for obvious reasons.
To be fair, you're probably right. Like I said originally, there's no way I'd personally want to OC a laptop. They generally have enough trouble keeping cool anyway.
