- 22 Jan 2004
Hi all,
i have a fractal design r4 case which has an inbuilt fan controller switch on the front with settings of 5v, 7v and 12v.
I was looking to change the fans that came with it for something with a bit more oomph. So thought about the Noctua Industrial 3000 Noctua NF-A14 IndustrialPPC 3000RPM PWM 140mm High Performance Fan.
My question is would these work ok off the fan controller and would they be pretty quite if i kept them at 5 or 7v most of the time? I'm a little worried about the power requirments as they are not supposed to be run off a mobo header so didn't want to fry my fan controller.
Also are there any better fans i should be looking at that are near silent at low rpm but push loads of air when needed at 12v?
Ta
Ferret
Ta
Ferret
