Ongoing Issues Gigabyte Z97X-Gaming 7 - Devils Canyon Core i7 4790K CPU & Motherboard Bundle
22 May 2013
Hi Guys,
I have replaced my computer as i had issues last week with a the specs below
VTX3D HD 7970 GHZ X-Edition 3072MB GDDR5 PCI-Express Graphics Card
Corsair Vengeance RED 32GB (4x8GB) DDR3 PC3-14900C10 1866MHz Dual/Quad Channel Kit (CMZ32GX3M4X1866C10R)
AMD Piledriver FX-8 Eight Core 8350 Black Edition 4.00GHz (Socket AM3+) Processor - Retail
Asus Sabertooth 990FX R2.0 AMD 990FX (Socket AM3+) DDR3 Motherboard
OCZ ZX Series 850W '80 Plus Gold' Modular Power Supply
i was getting an red led on the cpu light on MB and computer would not post
Now i have replaced everything expect the power supply AND ram with parts below and i still have no post but everything powers on and get an LED on board (A6) i reseated ram and tried stick on own but still the same.
Does anyone think that the Power supply could be the issue before i order replacement ?
Regards
John
Error code info
Ab - Wait user command in BIOS Setup.
A6 - Detect and install all currently connected SCSI devices.
remove the GPU and try to boot with onboard GFX
So you have the 8pin ATX plugged in near the CPU socket?
Try a single RAM stick, disconnect the drives and that is all you need to atleast get a image and enter the BIOS.
You have 4 sticks of RAM, the chances of them all being dead is extremely slim, so I guess it has to be the PSU?
That is if you have tried connecting to the onboard GFX without gfx card attached, tired each RAM stick inturn and not got any drives connected.
If you got a multimeter test the power good signal of the psu if it is present.
It is the gray cable on the 24 pin connector, it should be about 5v when the psu is powered up.
Also checking the power good via a multimeter is not a 100% foolproof as the motherboard measures the time the signal appear, the other good way of doing it is via a psu tester, like the one below, it cost about a tener.
thanks for the replies guys. i have been as thorough as possible with testing. although not tested psu. but as same symtoms as before it seems to be likely that it is the psu. but i will get one of those testers too for future use
If you wanna get the psu tester, I recommend the one with the lcd display that reads the power good signal delay time, there is cheaper one without the display but you will not be able to check the PG signal delay time if it is within specs.
What you have to remember is the codes showing are not actually error codes. They show the stage the Motherboard is at during POST. So if it stops at A6 its because its encountered a problem and stopped. A6 is not an error code. Its the last step the BIOS executed.
If you look in the manual on page 124 this shows the running steps that the motherboad goes through. So if you look at the next code in the sequence
A7 Activated all currently connected SCSI devices.
It is having problems with whatever is connected to the SATA ports. If you look on P124 its already got past the IDE detection phase. Could be something to do with the RAID controller or whats connected to the SATA ports used for RAID. I believe it says SCSI as thats just legacy.
The actual error codes are the bottom of P126 and none are A6 or AB.
What I would do as you have not mentioned whether this has been tried is make sure that you have nothing connected to any SATA ports and try also each stick of RAM you have in the first and then the last DIMM socket to see if it boots.
I take it you have tried clearing the CMOS too ? I would try that first and if it still perists then possibly a problem with the SATA/RAID Controller.
I would try stripping the system down to the bare minimum to see if you can get it to POST:
- board on something non-conductive outside the case (cardboard box?)
- Only plug in the CPU, cooler, single stick of RAM, and PSU. No HDD, SSD, optical drive, GPU, etc
- If it posts, update the BIOS to the latest one, then try adding one component at a time until you find the one that makes it fall over, or you have everything re-attached and the system is still booting.
