** WEEKEND ONLY: LOWEST PRICING IN EUROPE ON DDR4/DDR3!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
OcUK is attempting to lower the market price on memory in general, forcing our competitors to also reduce pricing and the manufacturers themselves. We pride ourselves in being leaders and having the absolute best customer service, so with prices like this there is no reason to buy elsewhere.
First of we have a 16GB DDR4 Kit which should be a good £50-£100 cheaper than our competitors for an equivalent performance 2400MHz quad channel kit with lifetime warranty:
TeamGroup Elite 16GB (4x4GB) DDR4 PC4-19200C16 2400MHz Quad Channel Kit - Black (TPKD416GM2400HC16QC01)
TeamGroup Elite DDR4 offers great value and great performance with superb looks with all black PCB and heatspreader design,.
Specification:-
- CPU Compatibility: Intel Haswell-E ( LGA 2011-3 )
- Chipset: Intel X99
- Capacity: 16GB (4GBx4)
- Quad Channel kit: Yes
- Tested Speed: DDR4-2400 MHz (PC4-19200)
- Tested Latency: 16-16-16-36
- Tested Voltage: 1.2V
- Registered/Unbuffered: Unbuffered
- Error Checking: Non-ECC
- Type: 288-pin UDIMM
- SPD Speed: 2133 MHz
- SPD Voltage: 1.2V
- Warranty: Lifetime
Previous Price: £149.99 Inc. VAT (Also lowest price in UK)
Price: £129.95 Inc. VAT (NO ONE IS CHEAPER, NOT EVEN CLOSE!)
Then on DDR3 whilst our competitors are saying a 1600MHz basic kit is a good price at £55-£65, OcUK says no, we will give you one of the highest performing kits on the market and at sub £50:
TeamGroup Vulcan RED 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLRED38G2400HC11CDC01)
Named after the god of fire in Greek mythology, the Team Vulcan is the combination of high-end craftsmanship and top-notch technology. The short version heat sink of Team Vulcan prevents difficulty in installation due to large and bulky heat dissipation device of motherboard. The arrow-shaped opening design helps increase heat dissipation. In addition, the explosively red color combined with diamond cut pattern not only shows great texture but also the crazy sensation of over-clocking speed.
Made of chips from major manufacturers, Team Vulcan passes series of harsh testing and verification procedures which have proven its stability and durability. Currently, DDR3 2400 CL10, DDR3 2133 CL11, DDR3 1866 CL9/10/11 and DDR3 1600 CL9 are available to cover the mainstream Dual- and Quad-channel specifications that pretty much satisfy the demands of players of all levels.
Features:-
- Module Type 240Pin Unbuffered DIMM Non ECC
- CL-tRCD-tRP-tRAS 11-13-13-35
- DRAM Density 128x8 / 256x8 / 512x8
- Data transfer bandwidth 19,200MB/Sec (PC3 19200)
- Heat Sink Aluminum heat-sink
- Working voltage 1.55V-1.65V
- Warranty Lifetime warranty
- Haswell & AMD Richland compatible
Previous Price: £56.99 Inc. VAT (Still cheapest in UK)
Price: £49.99 Inc. VAT !!!!
Check our entire memory range you will find OcUK has the best range of memory in the UK and pretty much has the best pricing on all brands.
Leading the way in driving memory prices lower!!!!!! :)
