There's nothing really worth upgrading to in all honesty, not within that budget anyway.
The obvious choice is 4790K+mobo but you're only going to get about a 20% increase at best and the majority of situations you'll not notice anything.
You'd probably see more benefit from a new monitor or something like that depending on how old your current one is, especially if it's G-Sync enabled.
yes i have a corsair k90, steelserise rival, iiyama 144hz monitor, ssd and razer naga 14.. my cpu and board are getting on a bit now
They may be getting on a bit now but the new tech will only give you a minor upgrade in terms of gaming performance, it's in the region of sub 15-20% which is just a waste of money.
If you really want to change something, get a 3770k and use that, but there's nothing I would change there. Even going x99 wouldn't make that much of a difference.
What are the exact issues you're having? My 2600k @ 4.5ghz with a 290 is perfect, can't ask for more.
Keep what you have!
5820K is the obvious step up but it's expensive what with the price of X99 motherboards and DDR4.. either that or a second hand 4930K+mobo if you can get one.
If you can't afford either of those then you'd probably be better off waiting to see what Skylake/Broadwell bring to the table.
yea i see what u mean im jist impatient i think..noob question alert ..so what benefits would i see getting a g-sync monitor im just not sure what it does.
G-SYNC technology synchronizes the monitor’s refresh to the GPU’s render rate, so images display the moment they’re rendered. The result: Scenes appear instantly. Objects are sharper. Game play is smoother.
In a nut shell:
