Need help/advise
16 Feb 2015
Hi Guys!
I need advise regarding this OcUK Tech Labs - Value 240 Kit water cooling kit is worth to buy it and to use on loop for cpu and gpu(procesor i5 and saphire radeon r9 280x ) or i must find a better one in this case more expensive? I mean kit looks cool but pump have enogh power for both gpu waterblock and cpu?
Thanks in advance:D
General rule of thumb would be 120mm of radiator per block and 1 extra 120mm.
So 2 blocks ie CPU & GPU would warrant 360mm of radiator.
Rich
Hi Guys!
Thanks in advance:D
What case are you using?
My point of view is to avoid Bay Reservoirs. They can be a bit hard to get rid of air bubbles, and they seem to pass more vibration through the case.
I've always preferred the look of tube reservoirs anyway :)
Hi i am using this Aerocool Strike-X ONE Advance Midi Tower Case and in my case space is a problem as i don't have space for triple fan radiator or for tube reservoirs....
You could easily mount a tube res in your HDD bays,plenty of space
You dont have to have to use a 360 rad.You just need 360mm of rad space.
So you could have a 240mm rad mounted in the front and another rad thats either 120mm/140mm mounted in the top of the case or on the back extractor fanmount
