PSU Cables
25 Jun 2009
does anyone know if i can get custom braided cables for my Be- Quiet PSU,
the standard cables look really bad............ thanks
You could send the PSU to someone like PexonPCs who will custom braid them for you
or get extensions like the Silverstone of BitFenix range of extensions
the only ones that look ugly are the MOBO cable and the 970 SLIs ....
the psu mobo end is a 20 pin and a 8 pin separate and it's finding this end that's hard............i guess the PCI is standard ???
it cant be an extension, because i can see the PSU so it'll still look ugly
they're made by the German company Be-Quiet, best known for their CPU Coolers.. it's the best PSU i've had by a long way, but it's let down by the cables, these need to be far less rigid with more attention to styling.....the PSU is dead silent and very heavy in its construction, it blows my previous Corsair out of the water, it's miles better.
http://www.pcper.com/reviews/Cases-...er-Supply-Review/Final-Thoughts-and-Conclusio
there's no need ever to upgrade, but if so i'd get this
http://www.overclockers.co.uk/showproduct.php?prodid=CA-066-BQ
Thanks Mal since corsair have dropped the ball on their psu's quality im looking for something else will look into these thanks again mal. Are the fan headers just 12v ones to run at full pelt on the psus?
the quality is extremely high, the 1200w version is one of the best PSUs in the world, but really expensive.
i guess it just depends on the luck of the draw but mine is dead silent, you hear nothing when you connect it up/ switch it on or off, all my other PSUs have made a noise of some sort but not this one.
it has components from Seasonic because i saw it mentioned in the review
my fans are connected to a fan controller and then to PSU via a plus, i've never used its fan headers
If you click on thread tools inside your post, top right of the page next to rate/search this thread. In there you see the option to close the thread.:)
