** THE TRUE MEANING TO A SAVAGE DEAL!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
You will not find 2400MHz kits for less anywhere else and certainly not on a flagship premium HyperX product with lifetime warranty and absolutely incredible performance and great overclockability. Forget all other brands, this stuff completely kicks ass and is now vastly cheaper than our competitors are selling 1333MHz cheap junk at, absolutely killing it on memory deals at the moment here at OcUK:
Kingston HyperX Savage Red 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (HX324C11SRK2/8) @ £46.99 inc VAT
Attack the competition with HyperX® Savage memory. Its unique, asymmetrical red heat spreader is made from high-quality aluminum and has a black PCB and a diamond cut finish to make your game shine and help you stand out in the crowd. The heat spreader dissipates heat so your system stays cool and reliable and its low profile fits under oversized CPU coolers. HyperX Savage is XMP Ready and comes in a range of speeds from 1600MHz to 2400MHz. Its trend-setting design puts you and your system ahead of the game.
Features:-
- Fast - top-performing modules available with low-profile heat spreader
- Unique - red, asymmetrical heat spreader sets new trends for PC builds
- Quality - aluminium die-cast heat spreader with a diamond cut finish
- Design - low profile to fit under oversized CPU coolers
- Reliable - 100-percent factory tested
- Guaranteed - lifetime warranty, free technical support
Specification:-
- Capacity 4GB-8GB (single), 8GB-32GB (kits)
- Frequency Speed 1600MHz, 1866MHz, 2133MHz and 2400MHz
- CAS Latency CL9-CL11
- Voltage 1.5V, 1.65V
- Operating Temperature 0°C to 85°C
- Storage Temperature -55°C to 100°C
- Dimensions 133.35mm x 32.8mm
- Compatible with H67, H97, P67, Z68, Z77, Z87, Z97 and H61 Intel chipsets, as well as A75, A87, A88, A89, A78 and E35 AMD chipsets
- Warranty: Lifetime
Was [£59.99] Inc. VAT
Only £46.99 inc VAT.
ORDER NOW
Kingston HyperX Savage Red 16GB (2x8GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (HX324C11SRK2/16) @ £95.99 inc VAT
Features:-
Specification:-
Was [£116.99] Inc. VAT
Only £95.99 inc VAT.
ORDER NOW
Kingston HyperX Savage Red 32GB (4x8GB) DDR3 PC3-19200C11 2400MHz Dual/Quad Channel Kit (HX324C11SRK4/32) @ £199.99 inc VAT
Features:-
Specification:-
- Compatible with H67, H97, P67, Z68, Z77, Z87, Z97, X79 and H61 Intel chipsets, as well as A75, A87, A88, A89, A78 and E35 AMD chipsets
Was [£239.99] Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
Take a look around, no one comes close.
The bad news is these prices are actually below cost, this is Kingston give us an exclusive supported deal/rebate to get down this low and it is only valid for the sale of 1000 units, once sold out the prices shall return to their previous price.
Any chance of a deal on 32 or 64 GB quad channel kits? £190 isn't much for 8x4 2400 I admit even if sold in pairs - are they likely to be the same revision? :-)
This is cheap.
Ok ddr3 ram was cheaper years back, but if you ain't got time machine that doesn't really mean anything.
2400MHz kits have never being this cheap and neither have 32GB kits, I believe this is a new lowest point in 2400MHz high capacity kits, but only at OcUK.
One of our competitors who sells Corsair, wants over £400 for a similar spec 32GB 2400MHz DDR3 kit, we just killed them. :)
Very good price on the 16gb 2400mhz ddr3 kit. See that the team group vulcan red is also just below £100.00. Can you confirm Gibbo, are the 8gb c10 vulcan kits now eol? Ideally id like to add another 8gb to my existing kit. But cant see them anywhere now.
GUYS PLEASE HELP SPREAD THE WORD ON OTHER FORUMS, DEAL WEBSITES ON THIS DEAL PLEASE!
This is killer deal, kills all the competitor, please help us spread it to bring prices down across the whole of Europe, we have 1000 units to go out so they won't be selling out overnight, should last a few weeks for sure. SO HELP SPREAD THE WORD PLEASE! :)
Yes gone.
DDR3 ranges are being reduced now as DDR4 production is hottening up, this could be the lowest we see DDR3 if more production shifts to DDR4 in coming months.
