Cheap upgrade to record/stream video games
Caporegime
30 Jul 2013
My nephew is 9 and has:
Intel i7 860 2.8Ghz
4GB RAM
AMD 6870
That card doesn't support the Raptr game recording/streaming though.
What would be the best upgrade to allow him to record for Youtube? I know they do those separate recording devices but they are about £100
Would a 2nd hand 7870 do the job? Do they work with the Raptr recording?
Edit: He only really plays things like Minecraft, Terraria etc.
I guess budget would be £100ish so AMD 280/285 are out of the question.
Recording / streaming is more a drain on the CPU than the GPU.
They could use OBS? It's not that easy to set up but once it's done it's just one button to start / stop.
depends how you stream with shadowplay you use the gpu and amd has a similar version but i forgot what its called which also uses the gpu. However there is software such as x-split and OBS which uses the cpu however can be slightly demanding for the cpu when running a game also.
Yes I know but the quality is pants on those.
