I damaged a little section of my front tyre's rubber rim protector a few weeks ago by driving too close to a corner. There is a loose piece of 10mm rubber.
I have had it checked by two garages and both are happy it doesn't warrant replacing the tyre or is unsage. Both said to just superglue it back.
I tried that but it didn't hold. Had a look online but can't find a recommended definitive product to use that I can get at Halfords/DIY places or online.
Any suggestions. I presume it will need not to dry brittle due to the movement/vibration, which is probably why superglue didn't stay.
