What's the obsession with little hatchbacks? How old are you?
Is this deal on the last of the old Corsa stock?
To be fair, looks better than the new one. And isn't it essentially the same engine any way...
No obsession, the Clio is the first small hatchback since i had a 106GTi back in the late 90's (tell a lie i had a Cooper S for 6 months back in 09).
Had a Z4M, VXR8, Subaru's and various hot hatches.
I'm 39.
"Efficiency takes a slight hit as a result, though, with 37.7mpg and 174g/km of CO2 claimed – considerably worse than its greener rivals’ figures."
Not a go at you, but really, who honestly gives a **** about these things when buying a Corsa VXR?
I mean there's the hateful little Econetic crapbox if you do.
Surely if you're of the moronic kind that does, you're not going to be looking at the top end Corsa model?
