- 10 Jan 2004
- Poland
My cpu didnt come with screws so i just glued it in, bunch of amateurs you lot!
I'm trolling with that one. I think you lot have been very harsh with the whole screw incident. I didn't realise that the opposite end of the screw head has like a twisty thing that brings the bracket together and fixes it. Usually a screw hole, if I can call it that has a bit of depth to it where the screw goes into, but the fact that there's nothing on the opposite side of the screw hole confused me.
Easy mistake.
You live and learn...not to post on the Graphic card section of OCukwould have got a better answer in general hardware rather than the elitest/fanboy section.
