** DDR4 GETTING CHEAP CHEAP, WELL AT OcUK!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Most of our competitors are still hovering around £200 for 16GB quad kits, whereas OcUK is nearly at £100 for such a kit, nearly half the price of our competitors. They are clearly sleeping! :D :D :D
TeamGroup Elite 16GB (4x4GB) DDR4 PC4-19200C16 2400MHz Quad Channel Kit - Black (TPKD416GM2400HC16QC01) @ £125.99 inc VAT
TeamGroup Elite DDR4 offers great value and great performance with superb looks with all black PCB and heatspreader design,.
Specification:-
- CPU Compatibility: Intel Haswell-E ( LGA 2011-3 )
- Chipset: Intel X99
- Capacity: 16GB (4GBx4)
- Quad Channel kit: Yes
- Tested Speed: DDR4-2400 MHz (PC4-19200)
- Tested Latency: 16-16-16-36
- Tested Voltage: 1.2V
- Registered/Unbuffered: Unbuffered
- Error Checking: Non-ECC
- Type: 288-pin UDIMM
- SPD Speed: 2133 MHz
- SPD Voltage: 1.2V
- Warranty: Lifetime
Was [£149.99] Inc. VAT
Only £125.99 inc VAT.
ORDER NOW
TeamGroup Elite 32GB (4x8GB) DDR4 PC4-19200C16 2400MHz Quad Channel Kit - Black (TPKD432GM2400HC16QC01) @ £269.99 inc VAT
Specification:-
- Capacity: 32GB (8GBx4)
- SPD Voltage: 1.2V
- Features: Intel XMP 2.0(Extreme Memory Profile)Ready
Was [£299.99] Inc. VAT
Only £269.99 inc VAT.
ORDER NOW
Crucial 16GB (4x4GB) DDR4 PC4-17000C16 2133MHz Quad Channel Kit (CT4K4G4DFS8213) @ £131.99 inc VAT
In the ever-changing world of technology, any component more than half a decade old is usually in need of an update. At seven years old and counting, that’s exactly the state DDR3 memory is in: computers can only do so much with it.
Since the introduction of DDR3 memory technology in 2007, processors have doubled in capability, SSDs have revolutionized throughput, and graphics cards have drastically increased frame rates, leaving memory as a limiting factor. With Crucial DDR4 Desktop Memory, crush the DDR3 memory bottleneck and unlock a new standard of performance.
Load applications faster and run demanding programs without lag. Crucial DDR4 memory debuts at 2133 MT/s – more than 30% faster than DDR3 memory technology.1 Even better, as DDR4 technology matures, speeds are projected to hit 3200 MT/s – twice what was possible on standard DDR3 memory.
Effortlessly multitask between apps, and empower your system to fire on all cylinders. Crucial DDR4 increases memory bandwidth by over 30%, allowing your system to handle more data at once. As DDR4 technology matures, bandwidths are expected to achieve up to 25.6 GB/s – twice that of standard DDR3. To maximize bandwidth, Crucial DDR4 memory is optimized for nextgen platforms that support four channel memory.
Get better performance – using less power. Operating at just 1.2V compared to 1.5V for standard DDR3 memory, Crucial DDR4 consumes 20% less voltage than standard DDR3 technology. Crucial DDR4 modules also contain other efficiency features, for an overall power reduction of up to 40%.
As a brand of Micron, one of the largest memory manufacturers in the world, Crucial DDR4 memory represents the future of computer performance. From the original DDR technology to DDR4, we’ve engineered the memory technologies that have powered the world’s computers for 35 years and
counting. When you choose Crucial DDR4 memory, you’re choosing memory that’s backed by a limited lifetime warranty2 and designed for the world’s leading systems. Don’t settle for anything less.
Specification:-
- 2133MHz (PC4-17000)
- CAS Timings: 16-16-16
- Voltage: 1.20v
Was [£169.99] Inc. VAT
Only £131.99 inc VAT.
ORDER NOW
Crucial 32GB (4x8GB) DDR4 PC4-17000C16 2133MHz Quad Channel Kit (CT4K8G4DFD8213) @ £251.99 inc VAT
Specification:-
- Voltage: 1.20v
Only £251.99 inc VAT.
ORDER NOW
Crucial Ballistix Sport 16GB (4x4GB) DDR4 PC4-19200C16 2400MHz Quad Channel Kit (BLS4C4G4D240FSA) @ £149.99 inc VAT
Designed for performance enthusiasts and anyone who simply wants to get more out of their system, Crucial Ballistix Sport performance memory helps you do just that. Give your processor the resources it needs to perform and make your computer faster and more responsive.
Memory is fun when it’s faster, when it’s stylish, and when it helps your system perform at a higher level. Compared to standard PC memory, that’s exactly what Ballistix Sport is engineered to do. Get faster speeds and run demanding applications with ease. Multitask at will with increased bandwidth. Strike first with better latencies and reduced load times. And achieve seamless responsiveness with exciting and affordable performance.
Getting more out of your system should be easy—and that’s exactly how we engineered Ballistix Sport memory. Featuring intuitive module designs, Intel® XMP profiles1 and more, we designed Ballistix Sport with the sole intent of creating affordable, easy-to-use performance memory. Installation is a cinch: just plugand-play, and get ready to win with little to no BIOS configuration.
Ballistix Sport performance memory is available in a wide range of module types, configurations, and heat spreader options. Sport modules are available in UDIMM/SODIMM form factors, DDR3/DDR4 memory technology, and tall/short height profiles. Pack more performance into nearly every type of system – yours included.
As a brand of Micron, one of the largest memory manufacturers in the world, Ballistix memory is built to last and delivers a higher level of performance than standard memory. For more than 35 years, we’ve engineered old-school DDR memory all the way to Ballistix Sport DDR4, which empowers you to seize an
affordable performance edge. Backed by a limited lifetime warranty2 and rigorously tested to some of the most demanding standards in the industry, Ballistix Sport performance memory has been thoroughly proven and is ready to make an impact in your system.
Features:-
- Speeds start at 2400 MT/s and faster speeds are expected to be available as DDR4 technology matures
- Faster speeds and responsiveness than standard Crucial DDR4 memory
- Four channel memory architecture maximizes data rates
- Integrated heat spreader and black PCB
- Easy plug-and-play installation
- Intel® XMP 2.0 profiles for easy configuration1
- Optimized for the latest Intel X99 platforms (X99 Platform required)
- Limited lifetime warranty
Specification:-
- 2400MHz (PC4-19200)
- Voltage: 1.20v
Was [£179.99] Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
Crucial Ballistix Sport 32GB (4x8GB) DDR4 PC4-19200C16 2400MHz Quad Channel Kit (BLS4C8G4D240FSA) @ £299.99 inc VAT
Features:-
Specification:-
- Voltage: 1.20v
Was [£349.99] Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
Avexir Platinum 16GB (4x4GB) DDR4 PC4-19200C16 2400MHz Quad Channel Kit (AVD4U24001604G-4M) @ £187.99 inc VAT
Avexir Platinum series is our best bang for buck DDR4 series and the one we expect to have the best supply. Using only Hynix IC this RAM offers no thrills looks, plain black PCB but promises to deliver on the overclocking front, in our own testing we have seen 2800-3400MHz speeds from clocking these modules. This makes them incredible value for money!
Specification:-
- Tested Latency: 16-16-16-39
- SPD Voltage: 1.2V
Was [£199.99] Inc. VAT
Only £187.99 inc VAT.
ORDER NOW
Avexir Platinum 32GB (4x8GB) DDR4 PC4-19200C16 2400MHz Quad Channel Kit (AVD4U24001608G-4M) @ £349.99 inc VAT
Specification:-
- SPD Voltage: 1.2V
Was [£379.99] Inc. VAT
Only £349.99 inc VAT.
ORDER NOW
Kingston Predator 16GB (4x4GB) DDR4 PC4-19200C12 2400MHz Quad Channel Kit - Black (HX424C12PB2K4/16) @ £179.99 inc VAT
Kingston Predator DDR4 is some of the most aggressive looking DDR4 available and looks menacing. Make your opponents fear you with Kingston Predator DDR4.
Specification:-
- Tested Latency: 12-13-13-35
- Tested Voltage: 1.20-1.35V
- SPD Voltage: 1.2V
Only £179.99 inc VAT.
ORDER NOW
OcUK is leading the way on DDR4 by a longshot and with DDR4 becoming mainstream later this year we are in a very good position to take hold of the market. :)
Specification:-
- SPD Voltage: 1.2V
ORDER NOW
I have this kit and on my Asus x99-S board (mobo/5930k/memory bundle purchased here) I have yet to see XMP working, the option is OFF in the BIOS. When you select XMP it defaults to the XMP option vanishing so not selectable! Can you confirm this Gibbo?
Selecting XMP via the mobo switch does nothing.
I shouldn't think much at all, at least in the short / medium term future anyway.
Being totally serious with the question. APU's rely heavily on the bandwidth from the memory so having more will be a bonus, but is there any bandwidth difference between a ddr3 and a ddr4 memory dimm at the same frequency?
