** Pre-Order Stock due very Soon Raspberry Pi 2 **
7 Feb 2011
Stoke on Toast
Stock is due to land in the next few days.
Raspberry Pi 2 Model B @ £31.99 inc VAT
The Raspberry Pi 2 Model B represents a major performance increase over its single-core based predecessors: up to six times faster in fact. As well as a new quad-core Cortex-A7 processor, the Raspberry Pi 2 Model B now features 1GB of RAM memory. The operating system kernel has been upgraded to take full advantage of the latest ARM Cortex-A7 technology and is available with the new version 1.4 of NOOBS software (See Note below). Backward application hardware and software compatibility has been maintained with the Raspberry Pi 1 Model A+/B+.
Specifications:-
- Broadcom BCM2836 900MHz ARM Cortex-A7 quad-core processor with VideoCore IV dual-core GPU
- GPU provides Open GL ES 2.0, hardware-accelerated OpenVG, and 1080p30 H.264 high-profile decode
- GPU is capable of 1Gpixel/s, 1.5Gtexel/s or 24GFLOPs with texture filtering and DMA infrastructure
- 1GB LPDDR2 SDRAM
- HD 1080p video output
- Composite video (PAL/NTSC) output
- Stereo audio output
- 10/100 BaseT RJ45 Ethernet socket
- HDMI 1.3 & 1.4 video/audio socket
- 3.5mm 4-pole audio/composite video out jack socket
- 4 x USB 2.0 sockets
- 15-way MPI CSI-2 connector for Raspberry Pi HD video camera (775-7731)
- 15-way Display Serial Interface connector
- MicroSD card socket
- Boots from MicroSD card, running a new version of the Linux operating system (See Note below)
- 40-pin header for GPIO and serial buses (compatible with Raspberry Pi 1 26-pin header)
- Power supply: +5V @ 2A via microUSB socket
- Dimensions: 86 x 56 x 20mm
Firmware looks for add-on boards that comply with the HAT (Hardware Attached on Top) design rules.
This allows the Raspberry Pi 2 Model B to set up the GPIO and load drivers to suit an expansion board automatically. For more information see: http://www.raspberrypi.org/introducing-raspberry-pi-hats/
All RS-supplied Raspberry Pi 2 Model B boards are Made in the UK
Note
Previous versions of NOOBS software (1.3.x) are NOT compatible with Raspberry Pi 2 Model B. You may program your own after downloading NOOBS 1.4 from: http://www.raspberrypi.org/downloads/
Approved power supply: 822-6373
Raspberry Pi 2 Model B cases: 819-3646, 819-3655 and 819-3658
Raspberry Pi 2 Model B is also available in boxes of 150: 847-2816
Supplied with
Getting Started guide
Raspberry Pi
The original Raspberry Pi Model B computer went on sale in February 2012 and set a new standard shattering the dominance of the PC in the home and education markets. Over 3 million boards in the various formats, A, B, A+, B+ and Compute have since been shipped worldwide. The original concept of the Raspberry Pi was for a high-performance computer board providing Internet access with HD graphics at very low cost. The boards provide a platform for children and adults from any background to acquire computer science knowledge and help develop the future World-Wide-Web and the Internet of Things. While the Raspberry Pi boards were designed primarily for education, they have become very popular with manufacturers of embedded systems. In order to support this market, the Raspberry Pi Foundation has ensured backwards compatibility with each new revision. The bare-bones Compute module is aimed specifically at the OEM manufacturer.
Only £31.99 inc VAT.
ORDER NOW
I am told this will fit too
Raspberry Pi Acrylic Case Model B+ Black @ £4.99 inc VAT
Rugged kit case made of Black acrylic for the Raspberry Pi (model B +) with openings for 40-pin GPIO & Camera
specifications:-
- Dimensions: 56 x 30 x 87 mm (W x H x D)
- Material: acrylic
- Weight: about 65 g
- Compatibility: Raspberry Pi - Model B +, 512MB
- I / O ports:
- 4x USB 2.0,
- 1x CSI camera module
- 1x DSI display port
- 1x microSD (HC) card slot
- 1x LAN (RJ-45)
- 1x GPIO (40-pin for Model B +)
- 1x Micro USB (Power)
- 1x Composite -Video / audio output (3.5 mm jack, 4-pin)
- 1x HDMI
- Special features:
- Opening for GPIO ribbon cable with 40 pins
- Compatible with Raspberry Pi Model B +
Only £4.99 inc VAT.
ORDER NOW
I am hoping to be in stock friday for the weekend. figured I'd list it now as I have about 30 units in total coming and they are pretty hard to come by.
appears they landed last night 3 sold already 7 left with 20 landing sometime next week.
EDIT
make that 6 left
PRetty sure you can just download the complete image you need put it on an SD and run it.
See above post #8
that basically gets you up and running then youd just need to configure it if required I can get a basic guide made with a few screen shots once mine gets here next week
Just ordered one to play about with. Didn't realise OcUK were stocking the newer model. :rolleyes:
Media centre/spotify streamer/tinker-with-box it shall become.
I've always wanted one of these to mess about with, I've always wanted to make an XBMC media thing.
Then I remember my TV is 2 ft away from my PC and connected via HDMI and I get sad I can't tinker with this stuff.
