How do you use the fuel scoop btw? I've read that you need to be close but not too close to certain stars!?!?
@JHeaton cracking!Nice to see there is a bit of civility even in pirates these days!
To be honest, every player who has interdicted me has been nothing but polite. I just disappointed them all because they happened to stop me when I had no cargo whatsoever.
With regards to fuel scooping, I'm not sure what the distance is, but the scoop automatically deploys when you're close enough to the star, at which point you get a couple of bars showing heat levels, fuel amount and scoop rate. As long as you make sure your heat level is always below 150%, you should be fine. You can only scoop from stars of types A, B, F, G, K, O and M, however. It takes a bit of practice, but you get used to doing it safely after a while.
