Is KFA2 a good make? never heard of it![]()
Are you not getting only 3.5 Gigs of Vram though ?
so its not worth replacing my gtx 780?
I'm thinking the same thing, so far some say the 970 is better than the 780 at 1080p, i'm not sure though, although i have had my 780 for nearly 2 years, it's difficult to keep the GTX780 below 80C with the reference cooler even in a welll ventilated and fan cooled case and even with the side panel off my Corsair 700D case, throttling is unwanted and i don't like GPU boost at all but something we have to live with unless you want to use third party bypass techniques to stop throttling but heat is an issue with my 780 always. 970 has its benefits over the 780 and that price quoted is fair and quite decent considering i paid just under £600 for the GTX780 in may 2013.so its not worth replacing my gtx 780?
which 980 for the money then?
Basically I have a ichill 780 getting repaired or replaced from OCUK to manufacturer but can take 28 days and I need my computer so gonna have to buy another card![]()
Gibbo has previously advised this cooler is one of the best - take that as you will![]()
Gigabyte 980 G1 or EVGA 980 SC ACX 2.0
