Looking for a definitive answer on using Multi 290X's, can brands be mixed?
31 Jan 2014
Hi, within the next week i hope to be building myself a new PC. :)
I have one AMD ASUS R9 290X Direct CU 4GB that i will be using.
If i wanted to use crossfire in the future, would i need another ASUS R9 290X 4GB?
Or can i use any 4GB, R9 290X?
Does the brand actually matter?
Thanks in advance.
Many thanks Shiari and AMDMatt.
Mr AMD rep :)
Must ask this! Are you saying i can use any R9 290 with any R9 290X or even any R9 295X2?
Sorry for asking a question that's probably been asked many times but i wanted to be completely sure before going ahead. Hope you understand. If i go this way i may throw more money at it depending on the expected results.
Mr AMD rep :)
Yes, Crossfire is extremely flexible in this regard. :)
My god, that's incredible.
Will be a Gigabyte Z97 G1.Sniper, 16GB Ram, i5 or i7, not sure yet, haven't bought the CPU.
Which CPU would you recommend?
Which PSU would you recommend?
Should be fine, I'd be looking at an i7 minimum for TriFire.
PSU would be a 1200W SuperFlower Platinum,
