- 26 Dec 2013
- 404 Not Found
I am using a D5 pump / EK Water Blocks EK-D5 X-RES 140 CSQ - Acetal.
The pump top has 2 inlets and 1 outlet. Can anyone see any problem with using the spare inlet as a drainage point? My idea was to have a pipe coming out attached to a stop valve with a plug on the end. Then when I want to drain my system I take the plug off and attach and extension then open the valve.
Would having this configuration of the spare inlet affect the pump at all?
My other option, but I'm not keen on, it to you a Y adapter on the outlet.
