Help me choose colours!! (PICS)
7 Mar 2005
Wolverhampton
Hi guys,
Whole house being re plastered and painted at the momet. We are putting a log burner in the living room but are stuck on a colour scheme.
The sofa will go on the back wall, facing the log burner wall. The TV will go to the left of the log burner. I will be putting a stack of logs in the arch to the right of the burner.
What do you think i should paint everything?
That's a tough question to ask someone,try some paint testing pots and go from there,everyone will have a different color scheme.....you only have to look at some peoples color choice in there pc's :)
Wall colours really are a personal thing, there's so many elements you need to consider:
What's the natural light like? North facing rooms are usually colder as they get less light, so warmer colours can help make the room feel more cosy. South facing rooms are usually (depending on the windows) flooded with light so bright colours can be dazzling.
Certain colours are linked with certain emotions/reactions e.g. reds and yellows are frequently used in restaurants as they are considered warm, relaxing and can increase appetite (so could be used in a dining room unless you're on a strict diet). Calming colours like blues and greens are good for bedrooms.
Then you've got the size of the room (linked with the natural light) darker hues can make a small space look smaller.
As pinkowl says, it also depends on the other objects you're going to be putting in the room. coordinating furniture, the floor material, lighting, soft furnishings, ornaments and pictures all plays a part in creating a unified space.
I've always been a fan of light flooring and white walls (for any room) as it acts as a blank canvas. You then create the atmosphere in the room with all of the other things mentioned above. This is especially true if you have a lot of pictures on the walls, because coloured walls can affect the look of the images.
However, when we get into our new house we're going to be using some very subtle soft accent colours in most of the rooms to add a bit of personality. It's a Victorian terrace so for a few of the rooms we'll be installing a dado rail and painting the lower half of the wall in a soft colour with the upper half white to hang pictures.
just paint is white for now?
Part of the problem of choosing colours for rooms is being overwhelmed by choice. from all of those swatches you see on paint stands...
Here's a tip - get a farrow and ball sample card / colour card. it's quite a concise selection full of very nice shades that all work well together. it limits you somewhat to a few choices, but they're all good choices. it negates the feeling of being swamped by pointless amounts of variations on the same shade, and the actual book F&B send you is really nice and the samples are acurate.
The room I'm working on now will be getting 2 F&B colours; I chose the carpet first of all - that's set. then I picked 2 F&B colours that worked with the carpet and eachother. it's very easy to tell if a colour doesn't work as it will imediatly irk you.
I'm not saying buy F&B paint; you don't have to just use their colours as a starting point
Just this morning I got jonstones to mix up two F&B colours in their covaplus emulsion (can also get dead matt if you want it) and it's the same colour for a fraction of the cost.
Splitface slate mosaic tiles on the chimney, used them in my kitchen and definitely going to use them on my next house
We have no furniture at all, nothing, we need to pick the colours of the room before we can pick our furniture lol !
I quite like the idea of red/white.
But, for example, what parts would go red and what parts would go white (arghhhh)
I'm thinking, back wall (facing log burner/tv) would be red, maybe also log burner chimny wall red, rest white?
In my experience, once you have an idea of the colour palette you want, go and pick your curtains etc before paint. You can have paint in any colour you want but there's only a limited number of fabrics. We did it the other way last time and it drove us mad trying to find curtains we liked even after we gave up trying to get reasonably priced ones.
We just painted the entire inside of the house Dulux trade Almond white (matt) and we're really pleased with it.
Not the most exciting colour but it goes with everything, is a stock item and can actually be touched up without having to repaint the entire room (huge bonus to us given my daughter has drawn on the wall more than once!)
I don't get the whole 'feature wall' thing. It's all a bit daytime TV DIY show to me.
Might just go with the above idea, paint it white.
Least i can add colour if i felt like it to certain walls!
The whole of my downstairs is white, it's open plan so wanted something that would work area to area, saved so much head pain deciding what colour.
I have done mine grey and yellow this week. Photo gives you an idea, room is very unfinished due to moving everything out and doing things in stages but you get the idea. Looks so plain with nothing on wall :(
