New Corsair PSU Cables
28 Feb 2015
Hello.
I have the Corsair RM650,and was considering buying the replacement red cables,which OCUK are selling.
Which set would I require,and how flexible are they when compared to the standard supplied set?
Thank you
The Corsair set doesn't include the 24 pin cable, so you would have to buy that separately for £14.99. That would bring the cost up to around £80.
The Cablemod ones are better value for money.
Thank you,will hopefully place an order tomorrow. Just watched a video on Youtube regarding the Cablemod set,nothing bad was mentioned :)
I have some for mine and they are so much better than Corsairs ribbon cables. Much more flexible and a better quality too.
Hi CableMod,
I have a Corsair RM650,and currently using the supplied flat ribbon cables. They are an improvement over the fixed version,but are not that easy to route around corners & twist.
I originally planned to buy the Corsair set,but they lack the ATX24 pin cable,hence the topic.
Lee43UK supplied links ,which seem like a better solution.
Basically I'm looking for a set of cables,which are designed for the RM series,very easy to route around corners & twist,and look nice lol
How would you rate the CableMod C to the Corsair set?
Thank you
Hi CableMod,
Thank you
our cables are VERY flexible because our ModFlex sleeve is based on Paracord - in terms of flexibility your best choice.
