- 6 Jan 2013
- Rollergirl
The following situation happened with my 970 SLI setup. Now I've changed to 980 SLI it's still happening, so it's either my set up or a Maxwell thing.
Firstly the voltage bug. Both 980s will run with one having a lower voltage than the other. However, if I overclock the card with the higher voltage by 30mhz more than the other, they both get the exact same volts.
Secondly, and the one that's bothering me...
GPU1 is at stock.
GPU2 is 30mhz higher clocked than GPU1
In Heaven, both run at 1.212v and core clock is 1392
All is good.
Now, if I slide the voltage up on both cards by the max allowed in AB (87mv) things don't go so well...
GPU1 sits at 1.256v and core clock is 1418
GPU2 sits at 1.262v and core clock is also 1418.
Then the cards start to throttle.
GPU1 throttles to 1.231v and core clock is 1405
GPU2 throttles to 1.237v and core clock is also 1405.
GPU-Z shows perfcap reason as Vrel/SLI.
PSU is Corsair HX850 Plus Gold, and rig draws 550w from the wall under full load. Maximum temperature throughout was 65c.
So, why voltage reliability problems and throttling? PSU?
GPU1 is at stock.
All is good.
