** 120MM FANS - PRICES SMASHED - ASK FOR DISCOUNT & PRICE MATCH**
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
We have slashed prices on some of our best selling 120mm Fan Lines and plan on keeping the prices that way until the end of the month.
If you are considering purchasing ANY fan from us, Please let me know and I will see if there is a discount that I can implement.
I will also beat any price you can find elsewhere.
Aerocool DS Edition Fan - White - 120mm @ £9.95 inc VAT
One of world’s most Silence fan with breakthrough technology and innovation.Beautifully finished “Dual Colour and Dual Material Fan”.The world’s first dual-layered fan blades - combination of plastic and rubber fan blades to absorb “Wind” noise.“Fish Eye” surface design on the back rubber side of the fan blades to minimize the air turbulence.Optimized fan blade angle design for a perfect balance of airflow and noise.Noise and shock reduction fan frame incorporating four Silencer Blocks and anti-vibration rubber pads on each mounting holes.Fluid Dynamic Bearing (FDB) delivers longer life span, higher precision rotation and anti-shock function.Low starting voltage of 3V.Four Anti-vibration screws are included for easier installation.Power cables are "black" sleeved with both 3-pin and Molex 4-pin connectors.Low speed 7V Voltage Reduction Cable included for ultra-low speed with unrecognizable noise.
- Dimensions: 120 x 120 x 25 mm (W x H x D)
- Weight: about 170 g
- Material: plastic, rubber
- Color: Black, White
- 12-volt operation:-
- speed: 1200 r / min
- Air flow: 92.9 m³ / h
- Static Pressure: 1.48 mm H2O
- Noise level: 15.8 dB (A)
- 7-volt operation:-
- speed: 800 r / min
- Air flow: 62.2 m³ / h
- Static Pressure: 0.99 mm H2O
- Noise level: 12.1 dB (A)
- Voltage: max. 12 V
- Starting voltage: 3 V
- Consumption: max. 2.4 W
- Connector: 3-pin, 4-pin Molex
- Life: 100,000 hours (MTBF)
In the box-:
- 3-pin to 4-pin Molex adapter
- 7 volt 3-pin adapter
- 4x fan screws
- 4x rubber decoupler
Was £12.49 Inc. VAT
Only £9.95 inc VAT.
ORDER NOW
Akasa AK-FN057 Apache Super Silent 120mm Fan - 4 Pin PWM @ £6.66 inc VAT
Super silent 12cm fan with S-FLOW blades supplying 30% more airflow than a standard fan at the same speed. The greater performance combined with PWM automatic speed control allows the fan noise to be kept to a minimum. The Apache fan creates more focused airflow providing blind-spot cooling, which makes it an ideal solution for a case or heatsink fan. HDB (Hydro Dynamic) bearings extend fan life and further enhance noise reduction. IP54 military standard ensures the fan is dust and moisture resistant. It’s powerful, quiet and tough!
PWM is a widely available feature on all current Intel and AMD platform based motherboards. It is more accurate than voltage regulation, energy saving and a fully automatic way of controlling the fan speed. PWM provides ultra quiet acoustics during normal PC use and high performance cooling under high system load. The Optional Akasa AK-CB002 cable adapter can provide the system with two additional PWM connectors if needed.
- Super silent APACHE fans in camouflage colours
- S-FLOW fan blade design delivers 30% higher airflow
- IP-54 military standard moisture and dust protection
- Super silent with PWM auto speed control
- Hydro Dynamic Bearing extends fan life up to 50,000 hours
- Dimension 120 X 120 X 25mm
- Bearing HDB (Hydro Dynamic Bearing)
- Speed 600 -1300 RPM
- Max airflow 57.53 CFM (97.74 m3/h)
- Sound level 6.9 -16.05 dB(A)
- Max static air pressure 2.64 mm-H2O
- Rated voltage 12V
- Connector PWM-4pin
Was £9.98 Inc. VAT
Only £6.66 inc VAT.
ORDER NOW
Akasa AK-191-SM Smoke Ultra Quiet 120mm Fan - 3 pin @ £3.29 inc VAT
Near silent 12 cm fan with distinctive Smokey coloured rotor blades and crystal clear frame. Designed with low air impedance blades, providing the ultra quiet acoustic experience.
- Dim: 120 x 120 x 25mm
- Rated speed: 1400 RPM
- Sound: 18.0 dB(A)
- Air flow: 49.74 CFM
- Bearing: Sleeve Bearing
- Life expentancy: 30,000/ hrs
Was £5.99 Inc. VAT
Only £3.29 inc VAT.
ORDER NOW
Akasa AK-191-BL Blue Ultra Quiet 120mm Fan - 3 Pin @ £6.66 inc VAT
Near silent 12 cm fan with distinctive Emperor Blue coloured rotor blades and crystal clear frame. Designed with low air impedance blades providing the ultra quiet acoustic experience.
- Sound: 18.0 dB(A)
Was £5.99 Inc. VAT
Only £6.66 inc VAT.
ORDER NOW
Arctic F12 TC Case Fan - 120mm @ £3.00 inc VAT
The ARCTIC F TC is a temperature controlled case fan, keeping your computer temperature at optimal level without any further setup or monitoring.
Dimensions F12: 120 mm
Fan Speed F12: 300 - 1350 RPM
Air Flow F12: 74 CFM / 125.1 m3/h
Bearing: Fluid Dynamic Bearing
Noise Level F12: 0.3 Sone
Net Weight F12: 136 g
Limited Warranty: 6 years
Was £3.98 Inc. VAT
Only £3.00 inc VAT.
ORDER NOW
Arctic F12 Pro Case Fan - 120mm @ £3.00 inc VAT
ARCTIC F Pro is a professional case fan that outperforms other generic case fans in the market. Its noise-performance ratio is superior as it offers high airflow while maintaining quiet operation at the same time.
Fan Speed F12: 1500 RPM
Air Flow F12: 54 CFM / 91.7 m3/h
Net Weight F12: 178 g
Was £3.98 Inc. VAT
Only £3.00 inc VAT.
ORDER NOW
Aerocool Shark Black Edition Fan - 120mm @ £4.49 inc VAT
Unique and Stylish "Shark Fin" Fan Blade design. 15 fan blades generates High Air Pressure and Air Flow - the most fan blades in the world !!!!
Innovative Fluid Dynamic Bearing delivers longer life span, higher precision rotation and anti-shock function. Duo Mode Operation - The Shark fan operates in both "Power" mode (12V) and "Silence" mode (7V - with adaptation of Voltage reduction cable). All cables are "black" sleeved. Accessories include a Voltage Reduction cable, a 3 to 4 pin converter cable,4 units of Anti-vibration Rubber Screws and 4 units of standard screws.
1 x Voltage Reduction cable (12V to 7V) w/ Black Cable Sleeving
1 x 3 to 4 pin converter cable w/ Black Cable Sleeving
4 x Anti-vibration Screws
4 x Standard Screws
Standard Connection (Power mode)
- Rated Voltage: 12V
- Starting Voltage: <=9.0V
- Power Consumption: 3.6W
- Rated Current: 0.3A
- Speed: 1500 RPM+-10%
- Air Flow: 82.6 CMF
- Air Pressure: 1.273 mm-H2O
- Noise: 26.5dBA
- MTBF: 100000 hours
Connect with Voltage Reduction Cable (Silence mode)
- Rated Voltage: (To FAN)7V
- Starting Voltage: <=6.0V
- Power Consumption: 1.56W
- Rated Current: 0.13A
- Speed: 800 RPM+-10%
- Air Flow: 32.5 CMF
- Air Pressure: 0.305 mm-H2O
- Noise: 12.6dBA
Was £6.98 Inc. VAT
Only £4.49 inc VAT.
ORDER NOW
BitFenix Spectre LED ORANGE 120mm Fan @ £4.49 inc VAT
Introducing the Spectre™ LED Fan Series from BitFenix. Engineered for both silent operation and maximum airflow, Spectre will keep your entire system well ventilated without making it sound like an airplane hangar. Spectre LED Fans are designed with sickle fan blades, which enhance airflow without producing excess noise. Spectre is also the first LED fan series on the market that supports on-the-fly LED light switching when used together with the BitFenix Hydra Fan Controller or BitFenix Survivor Chassis, allowing you to turn the lights on and off with a press of a button. Don't have either of those? No problem. Spectre can also be used as a regular LED fan with jumper-selectable on/off.
Powerful yet whisper-quiet - The Spectre Fan Series.
- Dimensions (mm): 120 x 120 x 25
- Current (A): 0.16±10%
- Speed (RPM): 1000±10%
- Air Flow (CFM): 43.5±10%
- Noise (dB-A): <20
- Air Pressure (mmH2O): 0.62
Was £6.49 Inc. VAT
Only £4.49 inc VAT.
ORDER NOW
Cooler Master 12cm Sickleflow Red LED System Case Fan - (CM-R4-L2R-20AR-R1) @ £4.99 inc VAT
Case cooling is becoming more essential these days. Quality fans with better airflow inside your chassis will give you a more stable system. The SickleFlow 120 with 2000 RPM is no doubt one of the best case fans in the market.
- Transparent dark-gray fan blades for better LED effect.
- Long life sleeve bearing for longer life expectancy.
- Strong air flow to fortify cooling efficiency.
- Silent operation as an excellent choice for case cooling.
- RoHS compliance.
- 120x120x25mm
- 2000rpm
Was £6.99 Inc. VAT
Only £4.99 inc VAT.
ORDER NOW
Noiseblocker BlackSilent Fan XL2 Fan - 120mm (1500rpm) @ £5.99 inc VAT
The fact that good quality does not have to be expensive is shown by the third version of the NB-BlackSilentFan series. The well-balanced properties of this bestseller make this inexpensive and high-quality series of fans the absolute bestseller throughout the world.
Our least expensive series of fans moves in such high circles, however, that other producers come off worse in direct comparisons even with their considerably more expensive "high-end" fans.
- Dimensions: 120x120x25mm
- Noise Level: 21dbA
- RPM: 1500rpm
Was £6.99 Inc. VAT
Only £5.99 inc VAT.
ORDER NOW
Noiseblocker NB-eLoop Fan B12-3 - 120mm (1900rpm) @ £10.99 inc VAT
Noiseblocker already have the largest range of fans aiming to be the quietest on the market.
Noiseblocker eLoop fans are designed to reduce as much frame vibration as possible to avoid resonation being transferred into the chassis.
The most striking feature of the Noiseblocker eLoop fan is a completely new wing design that makes noise levels in the air stream even quieter. This allows the use of a directed air flow with less wasted air flow.
The new fans are based on the research findings of Dr. Rudolf Bannasch Bionikers, who has developed his research with the basic principles of the rotor loop. The new technology has been in development for the past two years, then brought to the development laboratory at Noiseblocker.
Technical details:
B12-3 : 1900 rpm, 26.5 dBA, 121.2 m³/h
Noise level: max. 26.5 dB (A)
Speed: max. 1900 r / min
Airflow: max. 121.2 m³ / h
Starting voltage: 3.4V
Power consumption: 2.05 W
Connector: 3-pin
Life Expectancy: 140,000 hours
Warranty: 6 Years
Was £13.99 Inc. VAT
Only £10.99 inc VAT.
ORDER NOW
Xigmatek XAF-F1256 Blueline LED Fan - 120mm @ £6.98 inc VAT
XAF-F1256, copper bushing axis, is an optimized and premium quality 120mm fan, waveform for superb quietness and outstanding aerodynamic efficiency. Copper bushing axis can guarantee exceptional running smoothness and provide excellent long-term stability.
• Copper axis with long life sleeve bearing to provide long-term life and stability.
• Waveform and enhanced lubricant circuits to provide outstanding aerodynamic efficiency.
• Wave Shaped and small hub dimension generate extra high airflow.
• Wave Blade technology increases 25% of air flow and drops 10% noise.
• 4pcs. white LED.
Dimension - 120(L)x120(W)x25(H) mm
Voltage Rating - 12 V
Start Voltage - 9V
Speed - 1500 R.P.M.
Bearing Type - Copper Axis with Long Life Sleeve Bearing
Air Flow - 75.3 CFM
Air Pressure - 1.6 mmH²O
Life Expectance - 150,000 hrs
Noise Level - 24 dBA
Weight - 125 g
Connector - 3 pin
LED Color - White
Was £8.99 Inc. VAT
Only £6.98 inc VAT.
ORDER NOW
XSPC Xinrulian 120mm 1200RPM Fan @ £4.80 inc VAT
Low noise fan for radiators and heatsinks.
- 1200RPM
- Low Noise (~22dbA)
- Airflow 48.3 CFM
- Static Air Pressure 1.0 mmAq
- Operating Voltage Range 6.0-13.8V
- 3 Pin Power Connector
- RPM Monitor Wire
- 45cm Wire
- Open Corners
- 25mm Depth
Was £8.99 Inc. VAT
Only £4.80 inc VAT.
ORDER NOW
I need to get me three intake fans for the H440 (rather restrictive airflow at the front). What fans are going to be good and nice and quiet for getting some air into my case?
Don't care about colour as these are all hidden.
the noiseblockers in the OP are probably a good shout for this use.
I would suggest using a fan controller with them if possible
either that or consider a lower RPM model of the same fan
Silverstone SST-FQ121 FQ Series 1225 PWM - Watercooling Optimised Fan @ £5.99 inc VAT
FQ121 represents SilverStone’s pursuit of a design that balances performance and tranquility. Its included PWM module allows motherboard to control fan speed and regulate the temperature inside your chassis with optimal efficiency. FQ121’s nine-bladed design maximizes airflow with ridged edges to provide stable static pressure. These features not only improve ventilation but also decrease operating noise.
The features of the FQ121 make it perfect for watercooling, with high static pressure and low noise, this fan is perfect for use with low FPI radiators such as the XSPC RXV3 High Performance Radiators.
PWM design allows 1000~1800rpm fan speed control by motherboard
Optimum airflow, pressure and extremely silent performance
Innovative blade design focuses airflow with maximum efficiency
Air-inlet with optimized aerodynamic design reduces noisy air turbulence
Specifications:-
- Model No. SST-FQ121
- Material P.B.T.
- Color Blue blade/white frame
- Bearing P.C.F. bearing (Powder Copper Fluid Bearing)
- Rated Voltage 12V
- Start Voltage =7V
- Speed 1,000 – 1,800rpm
- Airflow 67.5CFM (max.)
- Static Pressure 0.54 – 1.82mmH2O
- Noise Level 16.4 – 24 dBA
- Life Time 150,000 hours
- Weight 143±5g
- Dimension 120mm (L) x 120mm (W) x 25mm (D)
Was £7.99 Inc. VAT
Only £5.99 inc VAT.
ORDER NOW
Scythe Kaze Jyuni 1600RPM Slipstream 120mm Fan @ £5.99 inc VAT
With the Kaze Jyuni 1600RPM Slipstream, Scythe's main aim was to increase performance without compromising noise levels. The Slipstream 120mm Case Fans have been developed solely by Scythe engineers. They found out that by reducing the dimension of the centre hub and the wider surface area of the fan blade increased the airflow.
- 3 & 4 Pin Connection
- Flow Rate: 84.5CFM
- 1600RPM
- Noise level: 20.5 dBA
Was £7.99 Inc. VAT
Only £5.99 inc VAT.
ORDER NOW
