- 25 May 2011
Am having a kitchen extension at the minute minute. Just wondering if you know of some control box that would allow me to control lighting via my android phone ??
Lightwaverf .. forget the wireless link, get a raspberry pi, transceiver and domoticz and you can operate all sorts of home automation
That sounds like an interesting setup, do you have a setup like this, if so it would be great to see a write up on how it's done!![]()
Yeah i run this setup, controlling lights, remote switches and my boiler, all through the raspberry PI and lightwaverf switches and relays.
All you need is the following
Raspberry PI
A http://www.uk-automation.co.uk/products/RFXCOM-RFXtrx433E.html (this is the transceiver that sends/receives signals)
Domoticz software (http://www.domoticz.com/)
and the relevant switches.
The RFXCom above works with a wide variety of different protocols, lightwaverf just being one of them.
Really easy to setup and get working, once the software is installed you can get domoticz to turn on lights at certain times of the day, control the boiler, check for movement in the property etc etc, its endless.
Theres also a good android app for domoticz http://sebastiaanschimmel.me/projects/dromotica.html
and i believe a IOS app has also been written.
That covers the basics, if you need any more info just ask.
I just run an old 256mb model b pi, domoticz is very light weight and runs fine on this.
The rfxcom is a tiny device with a small antenna on it and it plugs directly into the USB socket on the pi, no external power is required.
The rfxcom controls all the protocols, I haven't got any x10 equipment, as long as the device transmits over 433mhz and the rfxcom supports the protocol then it will work fine. Domoticz takes all the hard work out of it.
