- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
dont buy B Grade stuff from here, because they wont tell you what's wrong with it......esp the PC Cases, i've sent them a few emails this week and they've just fogged me off.
a pc case is worthless if it's damaged/scratched on the outside...........esp a Lian Li.......you want it to be damaged on the inside, because that's easy to fix, but they wouldn't tell me........i was quite cross about this !!!
As the previous case buyer at OCUK, its almost impossible to check each item, especially if there is more than 1 B grade quantity, if they checked it and tell you, a 2nd unit may get booked in, you order and you may get the other b grade item shippped to you and the issue may not be the reported reason.
