- 9 Apr 2012
And how would you stop non urgent cases? Some form of payment.
If you charged £5 that would cut I believe most of the time wasters. You don't need to differentiate; the people would do that for you.
It would also deter people who needed urgent treatment, putting more pressure on acute services.
Then what is the answer?
Anyone who is able to walk into A&E without bleeding from somewhere shouldn't be in A&E.
Happening across the country already. Lots of A&Es have embedded GPs or primary care centres.
Alternatively, A&E needs to have a fast turn around GP practice in front of it, so walk in patients are seen quickly and directed away if appropriate or then fast tracked into proper A&E with a shorter waiting time.
9) all sports injuries are automatically self funded
My local a&e has this. Walk in, get seen by a nurse and she filters the walking wounded to the gp on the other side of the hospital and the rest get to go through to a excellent a&e department where you seem to be processed in a very efficient manner.
I have thought about that one but then you are then adding a negative connotation to doing something that will make you healthier. There is no positive to getting wrecked out of your face.
We should be encouraging exercise because it has a benefit. We should not be supporting peoples bad alcohol consumption and excessive sugar consumption etc.
One thing I would do would be that if you present "sick" to work and need a "sicknote" then you are not given one for something that is possibly attributable to "bad" behaviour. Therefore, if someone presents to A+E with alcohol related problems and the wants a sicknote for "stress" then they don't get it unless they actually attend a program that will tackle the alcohol program. GP's shouldn't sign people off for something that is willingly self inflicted (for no potential benefit) and therefore it should be classed as deliberate non-attendance to work.
Going on from Minstadave said there are a number of other answers. Going back to the original post I made:
1) Fund it properly - this one is obvious we don't at the moment and the Tories have cynically undermined it here.
I don't think cost is really on your mind when you've broken your arm...
