Conservatory Vs Garden Pod
5 Nov 2011
Derbyshire
Bought a house and we're going to be completing in around 3-4 weeks. The only thing is the place doesnt currently have a "man space" for me and my growing amount of kit.
There is room for a conservatory of around 4x2m or room further down the garden for one of the new funky garden office pods things.
I have £10k absolute tops to pay for one or the other (pod is around £4300) but change would be much appreciated.
Would appreciate some community ideas as I really can't make my mind up.
Depends on if you are married or not,
if so a space away from the wife is a no brainer.
Even if single a 4x2m glass box is not worth the hassle
buy a big garden office.
Having had a conservatory on my previous house, I would never buy one again.
Way too hot in the summer - cacti wilted and died because it was too hot, and way to cold in the winter. The room probably only got a few weeks use throughout the year. A single story extension makes a lot more sense, and adds more value to your house.
Your wife will probably take the conservatory and fill it full of wicker furniture so you're probably better off with the pod.
Couldn't really recommend a conservatory - I've got a work top down one side of one I use for dabbling with electronics, etc. and temperature regulation as above is a pain in the rear.
Conservatory does work but you need roof blinds - something most people forget.
Ours reaches sauna temperatures last summer. It kills everything. Ours has the plastic sofa, chairs and glass table. In summer the chairs get pulled out onto the lawn instead.
Pod works but you need power going to it and security.
I just can't make my mind up. I'm expecting a price difference of £4k pod and about £10k conservatory.
Power and network to a pod isn't too much of a problem and having £5k in my pocket after just moving in is a carrot on a stick.
I just want to extract the best value I can for £10k
Only thing with a POD is that you have to get there when it's raining. You'll want a proper path, space for a coat rack and umbrella stand, something to dehumidify..
One of those log cabins turned into a man cave would be what i would go for if I had 10k and a big enough garden.
http://forums.overclockers.co.uk/showthread.php?t=18604169
Would love one but I think the cost of that would be monumental.
Path already there, porch to put wet shoes in included. Didn't think of dehumidifying.
You could probably have a custom built shed with proper slate roof, insulation, guttering etc for less.
WIll look into that
Rather than a conservatory, why not have an extension?
My first choice but keeping under £10k will be impossible I think.
What pods are you looking at? £4,300 sounds cheaper than I've generally seen them.
Quite a tempting price. Though I don't really need one.
I went to a clients the other day and they had a pod from these guys;
http://campingpods4u.com/
I'm basing £4300 on the largest with flooring done. I was really impressed with it, the build quality looked brilliant and it was brilliant inside.
This.
4x2m extension would be pretty close to 10k or less, depends on your glazing, that's where a lot of money goes.
I'm doing a 6m x 7.8m single story rear extension and its going to come in at £23k'ish, doing much of it myself though.
Those pods are quite cool though but a extension would surely get a lot more use, its right there.
