strange
15 Sep 2009
Birmingham
Strange query...I've got Virgin Media with the Super Hub 2 and my parents have VM too
Weird thing is there is one website that will connect on theirs but not mine.
If it's the same isp why would there be a difference
[moved to Internet forum]
The privacy settings maybe different. If using IE for example, check Internet Options, then Privacy tab. Check the slider is the same on both machines. While on these screen, check if certain sites have been blocked from the same panel.
Check your firewall settings too and restore to default settings if you must.
If you are using different security software, then one maybe setup different to the other.
I was able to access the site fine earlier in the day, but when I went on later in the day it kept doing the check your human verification before saying it wouldnt connect at all
clearly not, hope thats the case and not anything to do with being on a watch list....sounds like im some kind of criminal then
im sure I was typing the random letters in correctly but kept asking for another one
