Is there a better Intel gaming build sub £750?
You can have that board for sub £50 brand new from another etailers popular auction site page. I wouldn't usually say anything but £45 is a lot of money.
As above have a £750 absolute max, the pentium could always be recycled and used for something like a HTPC in the future. Just wondering if there can be improvements made on the build for gaming as it will be primarily used for that
Is there any merit in halving the size of your storage, save yourself approx 80, then maybe target a less expensive motherboard, and then grab a £150ish i5?
my 2p:
YOUR BASKET
1 x MSI Z97I Gaming ACK - Devil's Canyon i5 4690K CPU & Mini ITX Motherboard Bundle **£12 Saving** £285.98
1 x MSI Radeon R9 290X LE Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card £239.99
1 x SK Hynix 256GB SSD SH910A SATA 6Gb/s Solid State Drive (HFS256G32MNB-2201A) £84.98
1 x Phanteks Enthoo Evolv ITX Mini-ITX Chassis with Window £54.95
1 x SuperFlower Golden Green HX 550W "80 Plus Gold" Power Supply - Black £52.99
1 x TeamGroup Vulcan RED 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLRED38G2400HC11CDC01) £44.99
Total : £763.88 (includes shipping : ).
rather than selling off the pentium (and all its associated hassle), get a i5k outright but forgo the hdd for now.
then in a few months, get a hdd and a aftermarket cooler
the cost would be approximately the same either way.
Quick question, is the 970 worth the few quid over the 290x?
tough question. the answer would vary according to who you ask ;p
personally, i'd say no.
the 290x is cheaper (and although puts out 60w more heat), the performance of the 290x and 970 is roughly equal
that's true as long as you're not hitting the last 0.5gb of the 970, in which case, stutter galore
ps: the 4790k is not really needed for single gpu gaming, just stick to the 4690k instead and save £100
pps: 128gb ssd is not really sufficient these days. 256gb minimum especially if you're plonking down good money for a rig
Personally I'd go with the case you actually want, that's the bit that you'll see all the time and that's what you've got to fit stuff into, the rest of the bits can be picked up when you have a bit more money, get the case you want.
Also case, PSU, keyboard and mouse are the few components you can carry forward into new systems. If OP is on a budget I fully understand, but long term paying extra for these makes sense. I once used a Chieftec Dragon case that outlived 4 system builds, still got that case in storage.
