** THE WITCHER III WILD HUNT NOW FREE WITH QUALIFYING NVIDIA CARDS!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
NVIDIA strike hard with a truly incredible game promotion by giving away The Witcher III Wild Hunt codes with qualifying purchases. This is a yet to be released AAA title that will be priced in the £25-£40 region, which is a superb value adder. This game shall be bundled with:
  • GTX 960 Graphics Cards
  • GTX 970 Graphics Cards
  • GTX 980 Graphics Cards
  • Laptops with GTX 980M
  • Laptops with GTX 970M
NVIDIA PROMOTION: The Witcher III Wild Hunt PC Game - Email Download @ £35.99 inc VAT
You've geared up with a GeForce® GTXTM graphics card.
Now download The Witcher 3®: Wild Hunt for the PC FREE at redeem.GeForce.com
Your code may be used once. NOT FOR RESALE. Offer available through May 31, 2015
or while supplies last. Your code shall be emailed to you or shall be stored within your Overclockers UK account which you can access by loging into your account on the store!
Only £35.99 inc VAT - ONLY AVAILABLE WITH QUALIFYING NVIDIA PRODUCTS!!
ORDER NOW
NVIDIA GTX 960 RANGE - CLICK HERE!http://www.overclockers.co.uk/productlist.php?groupid=701&catid=1914&subid=2379http://www.overclockers.co.uk/productlist.php?groupid=701&catid=1914&subid=2379
NVIDIA GTX 970 RANGE - CLICK HERE!http://www.overclockers.co.uk/productlist.php?groupid=701&catid=1914&subid=1010http://www.overclockers.co.uk/productlist.php?groupid=701&catid=1914&subid=1010
NVIDIA GTX 980 RANGE - CLICK HERE!http://www.overclockers.co.uk/productlist.php?groupid=701&catid=1914&subid=1812http://www.overclockers.co.uk/productlist.php?groupid=701&catid=1914&subid=1812
OcUK Laptop Range (ONLY 980M & 970M models qualify)http://www.overclockers.co.uk/productlist.php?groupid=959&catid=1828http://www.overclockers.co.uk/productlist.php?groupid=959&catid=1828
Our best deals!
OcUK GeForce GTX 980 "Reference Design" 4096MB GDDR5 PCI-Express Graphics Card @ £469.99 inc VAT
The new NVIDIA GeForce GTX 980/970 is powered by the next generation NVIDIA Maxwell Architecture, giving you incredible performance, unmatched power efficiency, and cutting-edge features.
Maxwell is the most advanced GPU architecture ever made, designed to be the engine of next generation gaming. Inspired by light, it was designed to solve some of the most complex lighting and graphics challenges in visual computing. For the first time, gaming GPU's can dynamically render indirect light using the new VXGI (Voxel Global Illumination technology). Scenes are significantly more lifelike as light interacts more realistically in the game environment.
The GTX 980 is the worlds fastest GPU and the GTX 970 offers the most advanced performance in its class. Each delivers 2x the performance of previous-generation card, bringing new gaming experiences to virtual reality, and ultra resolution 4k displays.
Enable the detail of 4k monitors, on a 1080P display. DSR produces smoother images by rendering a game at a high resolution, then downscaling it to the native resolution of the display using advanced filtering.
GeForce GTX 980 and 970 cards support tear-free, super-fast NVIDIA G-Sync monitor display technology including 4k. Together, these technologies provide the most immersive and competitive gaming experiences possible.
Features:-
- Voxel Global Illumination Technology (VXGI)
- NVIDIA® Super Resolution technology
- NVIDIA® GameWorks technology
- NVIDIA® GameStream technology
- NVIDIA® TXAA Technology
- NVIDIA GPU Boost 2.0
- NVIDIA PhysX® Technology
- NVIDIA FXAA Technology
- NVIDIA Adaptive Vertical Sync
- NVIDIA Surround
- Support for four concurrent displays including: Two dual-link DVI, HDMI and DisplayPort 1.2
- Microsoft DirectX 12
- NVIDIA® 3D Vision® Ready
- NVIDIA SLI® Ready Technology
- NVIDIA CUDA® technology
- PCI Express 3.0 support
- OpenGL 4.4 support
- OpenCL support
- NVIDIA SHIELD Ready
- NVIDIA G-Sync Ready
Specification:-
- GeForce GTX 980
- GPU: GeForce GTX 980 (GM204)
- Core Base Clock: 1127MHz
- Core Boost Clock: 1216MHz
- Memory Clock: 7010MHz
- Memory Size: 4096MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 256-bit
- CUDA Cores: 2048
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 3x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Dimensions: 268.6 x 98.4 x 40 mm
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
Was [£509.99] Inc. VAT
Only £469.99 inc VAT.
ORDER NOW
OcUK GeForce GTX 970 "NVIDIA 970 Cooler Edition" 4096MB GDDR5 PCI-Express Graphics Card @ £299.99 inc VAT
This very special NVIDIA GeForce GTX 970 is the only one of its kind designed by our in-house VGA Guru Gibbo making this the worlds ONLY genuine reference 970 available in the world. Gibbo's design request were very specific, genuine NVIDIA 970 cooler, yes the crazy expensive one just like the 980 cooler and a NVIDIA BGA Board using all original NVIDIA components with absolute zero cost down in the design.
Infact Gibbo improved the design by changing the containers in which the inductors are located for better quality items to help reduce and eliminate any possibility of coil whine. We also instruct our factory to only build these cards with Samsung memory. So why buy this over any other 970, well it is most likely the quietest whilst under load (gaming) due to having the NVIDIA cooler and any chances of coil whine have being pretty much eliminated with the design changes Gibbo has had implemented.
So this card is ideal for those seeking as little noise as possible and the other major advantage is the NVIDIA cooler which offers much better cooling performance in smaller enclosures or when running in 2-way or 3-way SLI.
Finally of course this card is perfect for when Half Life 3 is finally released at some point in the future and of course the latest GTA V game which is now confirmed!
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- Genuine NVIDIA 970 Cooler with Visualizer
- Genuine NVIDIA 980 PCB
- Coil Whine reduction technology: We specify the capacitors/inductors to be enclosed in plastic containers as it helps reduce/eliminate coil whine
- GeForce GTX 970
- GPU: GeForce GTX 970 (GM204)
- Core Base Clock: 1050MHz
- Core Boost Clock: 1178MHz (Upto 1268MHz Boost)
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 145W TDP
- Warranty: 3yr
Was [£329.99] Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
KFA2 GeForce GTX 970 OC Silent "Infin8 Black Edition" 4096MB GDDR5 PCI-Express Graphics Card **WorldWide Exclusive** @ £277.99 inc VAT
Since Overclockers UK introduced our Infin8 system range, demand for high performance zero compromise systems has exploded. Our Infin8 brand represents performance hardware coupled with a unique and stylish aesthetic.
Since the release of high end Maxwell architecture, the hardware game has changed. The new GeForce cards offer revolutionary new technologies and class leading performance alongside low operating temperatures and impressive power consumption.
The GALAX GeForce GTX 970 OC Silent "Infin8 Black Edition" is a collaboration of one of the largest Nvidia board partners worldwide, Overclockers UK Graphics Specialist: Andrew Gibson and Overclockers UK Technical Specialist & Overclocking World Champion, Ian ‘8Pack’ Parry.
Originally the Galax 970 EX OC Black Edition was intended as a high performance option for customers looking for the ultimate gaming experience with class leading performance. Our close partnership with Galax allowed us to specify a list of important modifications that would make the GALAX GeForce GTX 970 OC Silent "Infin8 Black Edition" a real show stopper.
Primarily, to fit the Infinity aesthetic, we demanded that the external design of our Black Edition card was sleek and stealthy. Adding to the already imposing look of the Galax design, this new, aggressive appearance really highlights the intent behind this product.
Additionally to the colour change, we included a nickel plated I/O plate, heatsink and heatpipes to compliment the premium nature of the product. The already impressive backplate on the card has been accented with a stylish "Infinity: Inspired by 8 Pack" decal.
The imposing looks of the card would be nothing without the ‘go’ to back up all the show.
Building on the already impressive performance of the GTX 970 platform, world class overclocking expertise from 8Pack has been implemented to fine tune the BIOS of this card to achieve maximum safe, reliable performance from the GTX 970.
As an industry leading gaming and high end hardware specialist, Overclockers UK understands the importance of offering a product that meets a customer’s expectation. A major worry for any enthusiast is operational noise under load. We have used this knowledge to reduce coil whine by using higher quality components and also using glue to attach the inductors to the PCB to help reduce electrical vibrations which help reduce whine.
This collaboration with Galax has allowed us to build what we believe to be the finest example of a GTX 970 on the market today.
This product is exclusively available from Overclockers UK and Caseking group throughout UK and Europe. We suggest European customers visit www.caseking.de to purchase this card in Western Europe and Eastern European customers purchase from http://www.kellytech.hu/
Features:-
- OcUK Zero Coil Whine guarantee*
- Samsung memory guarantee
- All Black Design!
- Nickel plated I/O Plate
- Nickel plated heatsink and heatpipe
- All black shroud/cooling design
- Black PCB
- Black Backplate with Inspired by 8 Pack logo
- Inductors placed in higher quality containers and glued to PCB to reduce coil whine
- Extreme factory overclock with huge OC potential
- Anodized aluminum backplate protects components and reinforces the PCB
- All new Silence Extreme cooler reduces temps by up to 10C
- Silence Extreme technology switches to single fan cooling at idle for almost noiseless operation
Quad mixed-gauge heat pipes ensure maximum heat dissipation
- Copper base with solid aluminum cover
- 5 + 2 Phase enhanced power system with 8 + 6-pin inputs delivers up to 50% more power for overclocking
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Base Clock: 1178MHz
- Core Boost Clock: 1329MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DVI Port: 2x Dual-Link DVI, 1x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 8-Pin & 1x 6-Pin
- 450W PSU Required
- 150W TDP
- Dimensions: 260mm (L) x 120mm (H) x 40mm (W)
- Zero coil whine guarantee
- KitGuru Review: http://www.kitguru.net/components/g...rce-gtx-970-oc-silent-infinity-black-edition/
- Warranty: 2yr
*If your card emits any coilwhine when used on a decent power supply that is 80+ Gold rated or higher then OcUK will refund or exchange the card. These cards incorporate our exclusive Coil Whine Reduction technology to help reduce and eliminate any whine.
Was [£289.99] Inc. VAT
Only £277.99 inc VAT - FREE SHIPPING FOR ALL CUSTOMERS!!!
ORDER NOW
Palit GeForce GTX 960 "Reference" 2048MB GDDR5 PCI-Express Graphics Card (NE5X960S1041-2060F) @ £149.99 inc VAT
The GeForce® GTX™ 960 delivers incredible performance, power efficiency, and cutting-edge gaming technologies that only NVIDIA Maxwell™ technology can offer.
This is the perfect upgrade to advanced gaming, letting you dominate the competition with 60% faster performance and twice the power efficiency than previous-generation cards*. Unleash its massive overclocking potential and push your performance even further. Plus, it features VXGI for realistic lighting, support for smooth, tear-free NVIDIA G-SYNC™ technology, and Dynamic Super Resolution that enables 4K-quality gaming on 1080p displays.
The GTX 960 even gives you great gaming to go with NVIDIA GameStream™ technology that lets you stream PC games to NVIDIA SHIELD™ devices. *Compared to GeForce GTX 660
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 960
- GPU: GeForce GTX 960
- Core Base Clock: 1165MHz
- Core Boost Clock: 1228MHz
- Memory Size: 2048MB GDDR5
- Memory Bus: 128-bit
- CUDA Cores: 1024
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 6-Pin
- 350W PSU Required
- 120W TDP
- Warranty: 2yr
Only £149.99 inc VAT.
ORDER NOW
ASUS ROG G751JT-T7019H - 17.3" FHD LED / i7-4710HQ / Nvidia GTX970 3G / 16G / 1TB 7200 + 128G SSD / BD Read / Win 8.1 64B @ £1,259.99 inc VAT
The unbeatable gaming laptop with TurboMaster overclocking
G751 is an unbeatable gaming laptop thanks to its 4th-gen Intel® Core™ i7 processor and NVIDIA® GeForce® GTX graphics, with TurboMaster technology for stable GPU overclocking and ROG AudioWizard-enhanced audio for immersive gaming. Its intelligent dual-fan cooling system keeps everything cool even in the heat of battle, and special keys let you access Steam or share memorable gaming moments with the world!
Specification:
- LCD Cover Color & Decoration: Black
- Top Case Color & Decoration: Black
- On board processor: Intel® Core™ i7-4710HQ Processor, 2.5 GHz (6M Cache, up to 3.5 GHz)
- Operating System: Windows 8.1 (64bit)
- Office: Microsoft® Office 2013 Trial
- Chipset: Mobile Intel® HM87 Express Chipsets
- Memory Slot: 4x
- DIMM Memory: DRAM DDR3 8G *2
- Total System Memory: DRAM DDR3 8G *2
- Storage: SATA 1TB 7200RPM 2.5' HDD, SATA 128G 2.5' SSD
- Display: 17.3'//LED Back-lit//300nits//FHD 1920x1080 16:9//AG//NTSC:72%//EWV
- External video display modes: "HDMI 1.4
VGA max. 2048*1536 @85Hz refresh rate
Displayport 1.1A"
- Discrete/Share: Discrete
- Video Graphics: NVIDIA GeForce GTX970M (N16E-GT)
- Video memory: GDDR5 3GB
- Video Camera: HD web camera
- Optical Drive: [SATA] 9.5"mm 6X Blu-Ray (Read)
- Built-in TV-Tuner: N/A
- FingerPrint: N/A
- Wireless: 802.11ac+Bluetooth 4.0 (Dual band) -WIDI
- 3G/4G: N/A
- LAN: 10/100 Mbps
- Card Reader: SD?MMC
- USB Port: 4x USB 3.0
- Interface: "1x Microphone-in jack
1x Headphone-out jack (S/PDIF)
1x RJ45 LAN Jack for LAN insert
1x VGA Port (D-Sub)
1x HDMI
1 x Thunderbolt"
- Audio: "Built-in speaker
Built-in array microphone
Built-in subwoofer
Sonic Master"
- Weight (Kg): "3.60 KG (Without Battery)
3.80 KG (with 8 cell battery)"
- Dimension (cm): 41.6(W) x 31.8(D) x 2.30 ~ 4.30 (H) cm
- AC Adapter: "230W AC Adapter
Output : 19.5V DC, 11.8A, 230W
Input : 100~240V AC, 50/60Hz universal"
- Battery: 88WHrs, 4S2P, 8 cell Li-ion Battery Pack
- Keyboard Type: Illuminated Chiclet Keyboard
- Keyboard Specification: ASUS 417mm keyboard with 19mm full size key pitch and integrated numeric keypad
- Antivirus and Tool Software: "30 days Office 365 Home Premium
Power2Go
Adobe Reader
McAfee Internet Security 2012
MaxxAudio"
- Security :"Intel Anti-theft
LoJack"<br>
- Supplied Accessories: Without carry bag<br>
- Warranty: 2yr
Was [£1319.99] Inc. VAT
Only £1,259.99 inc VAT.
ORDER NOW
GIGABYTE P37X v3-CF2 Ultraforce gaming laptop, 17.3" FHD Anti-Glare with Wide Angle View, Intel Core i7-4720HQ, 2x8GB DDR3L, 2x128GB mSSD + 1TB 7200rpm HDD, NVIDIA GTX980M 8GB GDDR5 - Windows 8.1 @ £1,859.99 inc VAT
The 17.3" GIGABYTE gaming laptop P37X features a 4th generation Intel® Core™ i7 processor and a latest gaming discrete graphics NVIDIA® GeForce® GTX 980M with 8GB VRAM. Crafted to impress and outperform, P37X provides Quad-storage system with up to a pair of 512GB mSATA SSD and a pair of 2TB HDD within a 22.7mm chassis; yet encompasses exclusively Hot Swappable Bay slot for a flexible solution. The groundbreaking Macro Hub offers rapid response and tactile key feedback for complicated operations. To create the revolutionary gaming experience, GIGABYTE develops exclusive Supra-cool Technology, maintaining superior thermal cooling capability. Stunning Full HD wide viewing angle display delivers exquisite viewing experience, along with a premium stereo subwoofer and Dolby® Digital Plus™ Home Theater for uncompromised audiovisual feast. Forged by delicate craftsmanship, P37 looks to fuel gamers with unparalleled power while staying true to portability.
Ultimate NVIDIA® GeForce® GTX 980M: Unleash Your Gaming Soul
P37X features a NVIDIA® GeForce® GTX 980M GDDR5 8GB, capable of P10,000+ in 3DMark 11*, ensuring users a solid edge over the competition. Battery Boost 2.0 delivers an uncompromised gaming experience with 30% extra battery life at frame rate. Dynamic Super Resolution (DSR) upscale the native 1080p to 4K resolution for upgraded viewing pleasure.
Incredible Design, Insanely Light
The mix of innovative thermal design as well as continual commitment to user experience generates this super slim and lightweight gadget-22.7mm / 2.8Kg. P37 will surely reign the thinnest and lightest gaming laptop in its class.
Agility of Actions: Macro Function
P37 provides exclusive Macro keys and macro hub functions, capable of setting combination keys for complicated operations. With rapid responses of Macro Keys, you can trigger numerous attacks simultaneously, ensuring the pure dominance of the field.
Top-notch Thermal Solution: Supra-cool Technology
The innovative Supra-Cool technology features dual heat pipes plus dual fans for the CPU & GPU, ensuring excellent thermal conductivity for outstanding cooling. Stunning performance and superior stability has always been and will always be a GIGABYTE standard for gaming laptop, which is once again demonstrated on P37.
Fan Tweak: Customized Stability
Fan Tweak tailors your fan speed to different user scenarios, striking a perfect balance between system stability and needs for tranquility. 4 customizable modes offers for all-condition tweak options. Auto High Speed brings 95% cooling effect of Max Fan without the fuss while Auto Low Speed suits surfers who prefer quietness over the rest.
High Performance, Massive Quad-storage System
The P37 supports up to two 512GB mSATA SSD and two huge 2TB HDD, delivering high speed and massive storage options. The RAID 0 structure and extraordinary mSATA SSD read/write rate produces hot-pursued performance for serious gamers.
GIGABYTE RAID Storm
Incorporating 3 SSDs in RAID 0 array, P37 breaks speed barriers with lightning transmission above 1500MB/s, eliminating access time and loading screens and delivering an upgraded gaming experience. Unleash maximum speed 12.5X faster than single HDD and 3X faster than standard mSATA SSD. Enjoy the full spectrum of your games.
Outstanding Flexibility: Hot Swappable ODD/HDD Slot
Full HD Display with Wide Viewing Angle
The 1080p Full HD display grants wide viewing angle, rendering vivid color and sensational impacts. Sharing game scenes with your partners will no longer be a problem.
UHD / 4K Ready: Mini DisplayPort Out
P37 comes with a built-in Mini DisplayPort, capable of outputting to an external display for an ultra-high resolution up to 4K at 60Hz. Enjoy next-generation visuals and your favorite games on large screens now. Feast your eyes on the incredible details never before available.
Realistic Surround Sound by Dolby® Digital Plus™
Dolby® Digital Plus™ Home Theater provides exceptional performance by effectively eliminating sound distortion, enhancing volume and reinforcing even the smallest details of sound. The high-fidelity experience is perfect for gaming, music and movies.
Auto-adjust Backlit Keyboard
The P37 features an ambient-light sensing backlit keyboard. It adjusts the light emitted to the user's context, making typing in dimly lit conditions and gaming in the dark free of troubles.
802.11ac: 45% - 70% faster than regular 802.11n
802.11ac, the next generation of wireless, promises intensified signals and more stable connections. Enjoy stronger throughput, extended coverage, less speed decline, and above all, freedom to play anywhere with your P37.
LAN Optimizer: Double Network Speed
GIGABYTE LAN Optimizer boosts your network speed for gaming and browsing as much as twice. Geared with different user scenarios, LAN Optimizer manages network packets by the user defined priority for the best available online experience.
Non-stop Gaming with Windows Key Disabled
Windows Key may be disabled and enabled again through GIGABYTE exclusive LockWin Key function. Game free of interruption from now on. Seamless gaming sessions could never been easier.
Maximum Convenience: GIGABYTE Smart Software
GIGABYTE Smart Technology optimizes and integrates software applications, bringing users convenience to and a smart, efficient experience.
Specification:
- Outstanding Flexibility: Hot Swappable ODD/HDD Slot
- Display: 17.3", 1920*1080 Full HD, Wide Viewing Angle
- Processor Type: Intel Core i7 4720HQ
- Processor Cores: 4 (8 Threads)
- Processor Clock Speed: 2.60GHz (3.60GHz Turbo Mode)
- Hard Drive Supplied: 1 x 1000GB
- Hard Drive Size: 1000GB
- Solid State Drive: 128GB SSD x 2
- Hard Drive Speed: 7200RPM
- Memory Supplied: 2 x 8GB
- Memory Size: 16GB
- Memory Type: DDR3L
- Memory Speed: 1600
- Memory Socket: 2 x SO-DIMM
- Max. Memory Support: 16GB
- Graphics Chipset: NVIDIA GeForce GTX 980M
- Graphics Memory: 8GB GDDR 5
- Chipset: Intel HM87 Express
- Optical Drive: DVD Supermulti R/W
- Microphone: Built-in
- Audio: 1.5 Watt Speaker*2, Microphone, Dolby® Digital PlusTM Home Theater®
- LAN: 10/100/1000Mbps Ethernet
- Wireless: 802.11 b/g/n/ac
- Bluetooth: v4.0
- USB 3.0 Port(s): 2
- USB 2.0 Port(s): 2
- HDMI Port(s): 1
- Mini Display Port(s): 1
- VGA Port(s): 1
- Microphone Jack(s): 1
- Headphone Jack(s): 1
- LAN Port(s): 1
- Card Reader: SD
- Web Camera: HD type
- Dimension: 417x287x22.7mm
- Battery: Li-Polymer, 11.1V, 75.81Wh
- Product Weight (g): ~2.8Kgs
- Warranty: 2 Years
Was [£1889.99] Inc. VAT
Only £1,859.99 inc VAT.
ORDER NOW
Can you say if the game registration keys are for Steam or GOG.com?
I'm guessing the majority would want Steam, but it would be quite cool to see GOG codes for this - the GOG logo is on the image for the promo that was leaked last week!
daaaamn yoooou and these tempting offfeeers!
Will be ordering the infine8black over the next couple of weeks certainly. Gibbo, will these prices hold till the end of the month?
So Gibbo, do you think this will be part of the TX deal as well?
In the past NVIDIA have not included games with Titan, so really is an unknown, but seriously whether or not you get a FREE £30 game with a £1000 product or not will have no impact on its sales.
Pretty sweet deal for anyone buying one of those cards, Witcher 3 is a much anticipated title.
Is it for steam or gog? I'm more interested in steam for achievements and so forth and I was considering a 970 upgrade!
Is the kfa2 a good one? I was looking at the MSI one the other day which is better?
absolutely zero benefits from being an early adopter, we always pay more and miss out.
Yep, been there, done that, no more early adopting from me for anything.
However, when my brother bought a 970 from here on the strength of my recommendation, it did come with a Nvidia "choose your path" code, so at least it came with something.
Gibbo give us the X's!!!! we have loads of money to throw at you guys! we cant wait any longer :D
when will the tab be up on the shop page?
Well I cannot wait to sell the 1000 units sitting in my warehouse.
Unfortunately the I cannot put the tab live until NVIDIA say so.
*Of course all the above could be me fibbing and right now we know nothing.....
Ok thanks for the info and price slip :D
