I have to share this with our HID team... they have to see this for kicks!![]()
HID team? Hardware Integration Dairy team by chance?
Unplug keyboard, remove keycaps, flush out with IPA (inside the switches too), tip upside down and dab switches with cotton buds to hasten removal/evaporation of IPA, when dried out spray a little squirt of switch cleaning lubricant in the affected switches (the ones you sprayed IPA in), use cotton buds to absorb any excess and finally leave for a short while for that to evaporate. The IPA, switch cleaning lubricant and cotton buds may cost a few quid, but it's a lot cheaper than a new keyboard and they should last awhile unless you're a serial spiller. Alternatively buy some new Cherry MX switches, dismantle your keyboard and replace the dodgy ones.
Oh yeah, switch cleaning lubricant, pick your supplier, I have used Servisol Super 10.
Tap water will leave deposits on the keyboard... Best thing to use is alcohol.
I washed my sidewinder in redbull 3 times now. and one of them may of had a shot of jager in but how much ended up in my mouth before i messed up is unknown.
It still works to this day after a major rip-apart last year but it is rubber dome.. I do need a new kb
