** CORSAIR DDR4 2800MHz AT UK's LOWEST PRICES!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
OcUK is not just leading the way on DDR4 prices, but were doing it on Corsair as well, we are leaders, check these prices out for super-fast 2800MHz kits:
Corsair Vengeance 16GB (4x4GB) DDR4 PC4-23000C16 2800MHz Quad Channel Kit - Black (CMK16GX4M4A2800C16) @ £199.99 inc VAT
Vengeance LPX memory is designed for high-performance overclocking. The heatspreader is made of pure aluminum for faster heat dissipation, and the eight-layer PCB helps manage heat and provides superior overclocking headroom. Each IC is individually screened for performance potential.
The DDR4 form factor is optimized for the latest Intel X99 Series motherboards and offers higher frequencies, greater bandwidth, and lower power consumption than DDR3 modules. Vengeance LPX DDR4 modules are compatibility-tested across X99 Series motherboards for reliably fast performance. There’s XMP 2.0 support for trouble-free automatic overclocking. And, they’re available in multiple colors to match your motherboard, your components, or just your style.
Specification:-
- 2800MHz (PC4-23000)
- CAS Timings: 16-18-18-36
- Voltage: 1.20v
Was [£239.99] Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
Corsair Vengeance 16GB (4x4GB) DDR4 PC4-23000C16 2800MHz Quad Channel Kit - Blue (CMK16GX4M4A2800C16B) @ £199.99 inc VAT
Specification:-
- Voltage: 1.20v
ORDER NOW
Corsair Vengeance 16GB (4x4GB) DDR4 PC4-23000C16 2800MHz Quad Channel Kit - Red (CMK16GX4M4A2800C16R) @ £199.99 inc VAT
Specification:-
- Voltage: 1.20v
ORDER NOW
Corsair Dominator Platinum 16GB (4x4GB) DDR4 PC4-23000C16 2800MHz Quad Channel Kit (CMD16GX4M4A2800C16) @ £299.99 inc VAT
Dominator Platinum high-performance DDR4 memory is designed for world-class system builds. It's built with hand-screened ICs, undergoes rigorous performance testing, and incorporates patented DHX cooling for reliable performance in demanding environments.
The DDR4 form factor is optimized for the latest Intel X99 Series motherboards, and modules are compatibility-tested across multiple X99 Series motherboards for reliably fast performance. Extracting maximum performance is easy -- built-in XMP 2.0 support gives you trouble-free, automatic overclocking.
Dominator Platinum modules work with the Corsair Link system for temperature monitoring, and you can even enhance the subtle white LED lighting by adding a light bar kit (available separately) to match or contrast it with your system.
Specification:-
- Voltage: 1.20v
Was [£349.99] Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
The Vengeance kits are superb prices and as always OcUK is forcing the market price and trend for DDR4 down, you have OcUK to thank for brining DDR4 prices to the low levels they are now at across the whole of Europe. :)
OEM price has held for now.
Our cost on 5820k replenished stock has shot up due to us placing an order with weaker exchange rates.
GBP/Pound contines to weaken against USD, that means prices will keep going up until the pound gets stronger.
