I was about to pull the trigger on an i5 4690k/z97 upgrade to my Phenom 960T/880 computer, but now it looks like I might as well wait a bit for Broadwell....
I would - you may kick yourself for upgrading early!
An Intel-claimed 5.5% fits pretty much exactly with the ~3% figure we know from the lower-end parts.Found something very interesting: http://www.anandtech.com/show/9070/intel-xeon-d-launched-14nm-broadwell-soc-for-enterprise
Intel just launched 'Xeon-d' - featuring 14nm 8 core Broadwell CPU's, clocked at 2.0Ghz (2.2Ghz for the 6 core skew) at just 45W TDP.
The fact that an 8 core Broadwell clocked at 2Ghz has only 45W TDP bodes very well for Broadwell-K and Skylake, in my opinion. We also have to consider that Xeon-D has the Southbridge integrated into the die, that's bound to consume some of the TDP budget aswell, if only a few watts.
The 4 core Broadwell-K at 65w should be able to be clocked quite high, knowing this about the Xeon parts. I understand the Iris Pro with 128MB of l4 cache consumes some of the TDP budget, though I imagine them clocking to 4.0-4.3Ghz at least.
Intel also confirmed that Broadwell gives a 5.5% IPC increase over Haswell (see the slides in the article I linked for the source).
WTB some leaked engineering sample information!
Don't expect high clocking cpu's if you want to avoid feeling let down. Just because a xeon model fits 8 2GHz cores at a 45W TDP has no indication on the clock ceiling. They simply aren't refining and evolving their fabrication process with high clocks as their main objective.
When are these due? Itching to buy myself a new full sized motherboard to go in a Corsair 540 case but only want to do it when I'm upgrading to a new CPU as well.
I would love to see a big performance improvement, but there won't be. As stated a few posts back its all about power consumption and mass production. As it stands the die shrinks are doing a great job decreasing power consumption on the mobile market, silicon is easily made in bulk compared to graphene (which I hear is still in its infancy?)
When the competition put out something worthy of noting then Intel will up their game. As it stands you need a mini power plant to power competitive hardware.
Broadwell-K with 128MB of l4 cache should be a good 10% faster than Haswell, if it's clocked similarly to the 4790k. 5.5% IPC gain over Haswell, plus the 128MB l4 cache adds upto double digit performance gains, in CPU tasks, when using a dedicated GPU.
Skylake should be another 15-20% improvement over Broadwell, if rumours are true.
5.5% in some scenarios, not all - running benches we're less than 10% IPC improvement going from 1st gen i5 to haswell in some cases!
First to 5th generation I5 or I7 would definitely be way more than 10% in every scenario.
Would be interesting to see comprehensive tests from all 5 generations though, to see just how much things have changed.
will bring new levels of performance and power efficiency to Mini PCs and desktop All-In-Ones
Can you link me some of the tests?
