- 9 Feb 2015
Just built my new pc with an I5 4960k and a Gigabyte Z97X-SLI m/b and have been checking things with CPU-Z. I see the core speed go from 800mz and up beyond 3,5 gb. Not having owned an Intel chip this decade, I would hope that's normal for the speed to be that low when idle and jump when under load.
Also, this cpu is supposed to be 3.5gb but I am seeing speeds of 3.9gb and I haven't tinkered with any overclocking. The only thing I did in BIOS was to select the XMP memory so I can use my 2400mz ram at that speed. Before I set it, the memory speed was only 1333mz. Now it shows at 2400mz.
I did a little test with Prime95 and had temps around the 70c mark. It might be normal but I am used to seeing temps around the 50c mark with my old AMD II chip
