OcUK Staff
- 26 Nov 2014
- Stoke
That's right, buy the below bundle: -
"Recon H81 ITX" Intel Core i3/i5 Mini ITX Value Gaming Bundle from £264.95 inc VAT
Value is the word for the Recon series bundles but OcUK refuse to scrimp on components so quality is maintained. With the Recon bundles you can build an incredible value gaming PC without the worry of incompatible components. Powered by Intel's latest and greatest fourth generation processors and paired with 8GB of rapid DDR3 RAM, the Recon H81 ITX is the perfect base for any gaming system.
Why You Should Buy This Bundle?
- Prebuilt and configured. Just "plug and play"
- 8GB Dual Channel DDR3 memory delivers fast load times
- Two or four core processing power for superior computing performance
Bundle Specification
- CPU: A choice between the superb Intel Core i3 and i5 processors
- Motherboard: Asus H81I-Plus Intel H81 (Socket 1150) DDR3 Mini ITX Motherboard
- RAM: 8GB 1600MHz Dual Channel DDR3 RAM
- Cooler: Raijintek Aidos CPU Cooler Black
Service Package
- Full 24 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Note - OcUK recommend a quality brand PSU for use with all our bundles such as the Superflower Leadex and HX range.
*Please allow 7 working days for your system to be built and configured. This may take longer during busier periods.
Only £264.95 inc VAT (i3) or £329.99 inc VAT (i5)
ORDER NOW
And get a Bitfenix Colossus Mini-ITX Chassis worth £64.99 to put it in for FREE!
BitFenix Colossus M Mini ITX - Black @ £64.99 inc VAT
The spacious interior offers two preinstalled 120mm front and rear fans, and includes the option to install up to five 120mm fans for extra cooling boost. Up to five 3.5" drives or seven 2.5" drives in total can be installed, or for those looking to run high-end graphics cards up to 330mm, the 3 bay FlexCage™ can be easily removed. Colossus Mini-ITX supports installation of thick 240 mm radiators on the top or front, and the easily removable bottom dust filter prevents from dust accumulating dust inside the case over time. Colossus Mini-ITX is the perfect choice for enthusiasts who are looking for compact stylish case with excellent water cooling support and massive storage options.
Features:-
- Futuristic Form – Bold lines with a compact design
- LiteTrak™ Technology – Smooth multimode lighting with three colours and an included pulse mode
- Unmatched Flexibility – Supports long graphics cards and up to 240mm water cooling radiators
- Maximum Storage Potential – Five 3.5" HDDs or eight 2.5" SSD locations available
- BitFenix FlexCage™ - Modular hard disk cage can be completely removed for added flexibility
- SuperSpeed USB 3.0 – Two ports included for blazing file transfers
- BitFenix SofTouch™ Surface Treatment – Luxurious matte finish and soft feel
- Friendly Installation – Tool-free drive locking mechanisms, cable management and filtered intakes
Specification:-
- Materials: Steel, Plastic, SofTouch™
- Colours (Int/Ext): Black/Black
- Dimensions (WxHxD): 250 x 330 x 374mm
- Motherboard Sizes: Mini-ITX
- PCI Slots: x 2
- Power Supply: PS2 ATX (bottom, multi direction)
- Extras: LiteTrak™ lighting system, SofTouch™ surface treatment, tool-free drive locking mechanisms, filtered intakes
Drives:-
- 5.25" Drive Bays: x 1
- 3.5" Drive Bays: x 5
- 2.5" Drive Bays: x 8 (5 + 2 + 1 )
Cooling:-
- Top: 120mm x 2 (optional)
- Front: 120mm x 2 (1 included) or 140/180/200/230mm x 1 (optional)
- Rear: 120mm x 1 (included) or 140mm x 1 (optional)
I/O:-
- USB 3.0 x 2, HD Audio
Only £64.99 inc VAT.
ORDER NOW
This is what your wallets will think...
Service Package
ORDER NOW
Features:-
Specification:-
- PCI Slots: x 2
Drives:-
Cooling:-
I/O:-
ORDER NOW
