I'm having a similar experience with mine... A side fan definitely helped - knocked about 5c off load temps.
Anyone know if changing the tim will help? I've seen big differences in the past using IC Diamond on cards with the reference cooler, but I'm not sure if it'll make a difference with my setup (Twin Frozr)
you would be shocked how bad some manufacturers apply TIM, changing to something ICD can help by a few degrees
