Hey all,
doing my first ever build, so i'm fumbling along in very slow/small steps. mostly going okay, but i'm about to fit the vid card and i'm confused, as regards power.
the box came w/ a "speed setup" booklet (2 pages of English) and it's useless to a noob like me who has no experience. it says "reconnect the power cables" and has some drawings, none of which match the 2-into-1 cable in the box. one of the other review sites notes the card has "moved from the stock dual six-pin PCIe power connector setup to a single six-pin PCIe power connector sitting alongside a single eight-pin PCIe power connector."
so basically, what do i do? do i stick a 6-pin on it or an 8-pin? why does it have both? why is there a 2-into-1 cable, don't i just stick a 6-pin from my PSU onto the card, or onto the 2-into-1 and leave the other connector unused?
edit - found another link saying the card *is* powered by a 6-pin and an 8-pin, so i'm still confused re the 2-in-1, do i put one 8-pin from the PSU into the card and then 2 into the converter and then that into the card? that would seem more like three power connections.
thanks in advance.
thanks in advance.
