Hi there
Some epic deals for you guys to check out:
Sapphire AMD Radeon R9 295 X2 8192MB GDDR5 PCI-Express Graphics Card @ £499.99 inc VAT
No matter what the game or the resolution you can now select the maximum settings even at 4k resolution and enjoy fluid ultimate smooth framerates in latest games such as Titanfall, Diablo 3, Watchdogs and even potential upcoming games such as GTA V and Half Life 3 should they surface.
Featuring a pair of 290X Hawaii GPU's fused onto a single PCB with an advanced PLX chip along with only requiring 2x 8-Pin power connectors.
The other major feature of the 295 X2 is its cooling solution which truly does keep the cards temperatures around 60c even after gaming for hours and it also manages to do this in more or less silence with zero throttling of the cores themselves. Making it one of the smoothest, quietest and easily most powerful graphics card on the market today. If you really crave the most powerful and have or are considering a 4k monitor for gaming then the 295 X2 is the card for you.
If your demands are truly the most powerful experience possible then these cards work great in Crossfire (4 GPU's) and you will be able to smash benchmarks to pieces and have no slow downs in games.
Specification:-
- GPU: 2x Hawaii XT
- Hybrid Liquid Cooling
- Litecoin Hash Rate: 1600-2000
- Stream Processors: 5632
- ROPS: 128
- Core Speed: 1018MHz
- Memory Speed: 5000Mhz
- Memory interface: 1024-Bit (2x 512-Bit)
- Memory capacity: 8192MB GDDR5
- PCI-Express X16 lane required
- 850W or greater PSU required with genuine 8-Pin PCI-E cables such as Silverstone 1500W
- Case capable of fitting such a long card and support for a 120mm radiator
- Dimensions: Card is 307x111x65mm and Cooler is 153x120x63mm
- Power Connectors: 2x 8-pin
- Display Outputs: 1x Dual Link DVI, 4x Mini-DisplayPort
- Warranty: 2yr
Was [£679.99] Inc. VAT
Only £499.99 inc VAT.
ORDER NOW
MSI Radeon R9 290X Gaming Edition 8192MB GDDR5 PCI-Express Graphics Card @ £289.99 inc VAT
AMD Radeon R9 290X is a new graphics card powered by the latest AMD Radeon™ R9 290X graphics-processing unit (GPU). 8GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290X also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification:
- Radeon R9 290X
- Backplate included: Yes
- GPU: Hawaii XT
- Litecoin Hash Rate: 850-1000
- Stream Processors: 2816
- ROPS: 64
- Core Speed: 1040MHz
- Memory interface: 512-Bit
- Cooling: MSI Twin FrozR Gaming Cooling
- 600W or greater PSU required
- Power Connectors: 8-pin + 6-pin required
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort
- Warranty: 3yr
Was [£299.99] Inc. VAT
Only £289.99 inc VAT.
ORDER NOW
MSI Radeon R9 290X LE Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card @ £239.99 inc VAT
AMD Radeon R9 290X is a new graphics card powered by the latest AMD Radeon™ R9 290X graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290X also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification:
- Radeon R9 290X
- GPU: Hawaii XT
- ROPS: 64
- Core Speed: 1020MHz
- Memory capacity: 4096MB GDDR5
- Warranty: 3yr
Was [£249.95] Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
Asus GeForce GTX 980 DirectCU II OC Strix 4096MB GDDR5 PCI-Express Graphics Card @ £455.99 inc VAT
The new NVIDIA GeForce GTX 980/970 is powered by the next generation NVIDIA Maxwell Architecture, giving you incredible performance, unmatched power efficiency, and cutting-edge features.
Maxwell is the most advanced GPU architecture ever made, designed to be the engine of next generation gaming. Inspired by light, it was designed to solve some of the most complex lighting and graphics challenges in visual computing. For the first time, gaming GPU's can dynamically render indirect light using the new VXGI (Voxel Global Illumination technology). Scenes are significantly more lifelike as light interacts more realistically in the game environment.
The GTX 980 is the worlds fastest GPU and the GTX 970 offers the most advanced performance in its class. Each delivers 2x the performance of previous-generation card, bringing new gaming experiences to virtual reality, and ultra resolution 4k displays.
Enable the detail of 4k monitors, on a 1080P display. DSR produces smoother images by rendering a game at a high resolution, then downscaling it to the native resolution of the display using advanced filtering.
GeForce GTX 980 and 970 cards support tear-free, super-fast NVIDIA G-Sync monitor display technology including 4k. Together, these technologies provide the most immersive and competitive gaming experiences possible.
Features:-
- Voxel Global Illumination Technology (VXGI)
- NVIDIA® Super Resolution technology
- NVIDIA® GameWorks technology
- NVIDIA® GameStream technology
- NVIDIA® TXAA Technology
- NVIDIA GPU Boost 2.0
- NVIDIA PhysX® Technology
- NVIDIA FXAA Technology
- NVIDIA Adaptive Vertical Sync
- NVIDIA Surround
- Support for four concurrent displays including: Two dual-link DVI, HDMI and DisplayPort 1.2
- Microsoft DirectX 12
- NVIDIA® 3D Vision® Ready
- NVIDIA SLI® Ready Technology
- NVIDIA CUDA® technology
- PCI Express 3.0 support
- OpenGL 4.4 support
- OpenCL support
- NVIDIA SHIELD Ready
- NVIDIA G-Sync Ready
Specification:-
- GeForce GTX 980
- GPU: GeForce GTX 980 (GM204)
- Core Base Clock: 1178MHz
- Core Boost Clock: 1279MHz
- Memory Clock: 7010MHz
- Memory Size: 4096MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 256-bit
- CUDA Cores: 2048
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 3x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x -Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
Was [£491.99] Inc. VAT
Only £455.99 inc VAT.
ORDER NOW
Asus GeForce GTX 980 Matrix Platinum 4096MB GDDR5 PCI-Express Graphics Card @ £539.99 inc VAT
The world’s record GPU frequency of 2.20GHz was set on Nvidia GeForce GTX graphics cards made by Asustek and EVGA. While it is hard to believe that the GM204 GPU can be pushed further towards 2.30GHz – 2.40GHz, the new Asus ROG Matrix Platinum GeForce GTX 980 graphics card is designed to do just that when put under extreme overclocking by the professionals such as 8 Pack.
Asustek Computer on Wednesday unveiled its new graphics card that has all chances to become one of the best graphics cards for overclocking ever produced. The Matrix GTX 980 boasts not only a powerful DirectCU II cooling system (featuring two fans and five heat-pipes) and custom design of printed-circuit board, but it features extremely sophisticated 14-phase voltage regulator module (VRM) that can do magic things for overclocking as well as some other technologies for those, who want to push the graphics card to the extremes.
The digital 14-phase VRM is based on concrete-core chokes, solid-state black metallic capacitors and hardened MOSFETs. The board features two 8-pin PCIe auxiliary power connectors that can deliver up to 300W of power to the graphics board (in addition to 75W supplied through PCIe x16 slot) and one 4-pin Molex connector for memory defroster power loop. When cooled to sub-zero temperatures during extreme overclocking, the memory defroster keeps the memory chips just above freezing, preventing cold bugs from hindering overclocking.
e Asus ROG Matrix Platinum GeForce GTX 980 4GB will be the most powerful Nvidia GM204-based graphics card in Asustek’s lineup. The graphics processor of the monster graphics adapter is rated to run at up to 1342MHz out-of-the-box, a significant increase from 1216MHz recommended by Nvidia.
The ROG Matrix Platinum GTX 980 is the fourth GeForce GTX 980 graphics card in Asus’ family. The company carries a reference GeForce GTX 980, Strix GTX 980 with DirectCU II cooler and Poseidon GTX 980 featuring a hybrid cooling solution that use similar PCBs with 10-phase VRMs as well as the new ROG Matrix Platinum GTX 980 card that sports a brand-new printed-circuit board with 14-phase VRM as well as DirectCU II cooling system.
The current 2.20GHz GPU clock-rate records were set by professional overclockers using Asus Strix GTX 980 and EVGA GeForce GTX 980 Classified ACX 2.0 graphics cards that were cooled by liquid nitrogen cooling.
The Strix GTX 980 sports custom design of printed-circuit board with 10-phase digital VRM, the same one is used by Asus Poseidon GTX 980 graphics card, which has proven to be among the best in the industry. EVGA’s GTX 980 Classified sports custom PCB with 14-phase VRM, its voltages can be controlled using a special device. It will be very interesting to see whether Asustek’s engineers have managed to create a better voltage-regulating module than developers from EVGA and whether such VRM actually enables better overclocking. Will the record of 2.20GHz/9GHz (GPU/memory) stand or fall?
Features:
- DIGI+ VRM with 14-phase Super Alloy Power: deliver 30% less power noise and 2.5X greater durability.
- Japanese-made black metallic capacitors: 20% better temperature endurance and 5X longer lifetime usage.
- ROG LED light: pulsate in glorious red when the card is active.
- GPU Tweak: modify clock speeds, voltage and more via an intuitive interface.
- GPU Tweak Streaming: let you share on-screen action in real time – so others can watch live as games are played.
Specification:-
- GeForce GTX 980
- Core Base Clock: 1253MHz
- Core Boost Clock: 1342MHz
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x8-Pin
- 600W PSU Required
- 375W TDP
- Warranty: 3yr
Was [£569.99] Inc. VAT
Only £539.99 inc VAT.
ORDER NOW
OcUK GeForce GTX 980 "Reference Design" 4096MB GDDR5 PCI-Express Graphics Card @ £449.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- Core Base Clock: 1127MHz
- Core Boost Clock: 1216MHz
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Dimensions: 268.6 x 98.4 x 40 mm
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
Was [£479.99] Inc. VAT
Only £449.99 inc VAT.
ORDER NOW
MSI GeForce GTX 980 Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card @ £455.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- Core Base Clock: 1216MHz
- Core Boost Clock: 1317MHz
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- 500W PSU Required
- 200W TDP
- Warranty: 3yr
ORDER NOW
LG 29UM67 29" FREESYNC Gaming Super-Wide Widescreen LED Monitor - Black @ £279.95 inc VAT
AMD FreeSync technology is an innovative monitor technology, based on free and open industry standards, to eliminate the tearing and stuttering that has plagued PC gaming for 30 years,” said Roy Taylor, corporate vice president of ISV/IHV partner group at AMD. “We are pleased that LG Electronics stands with us with truly exciting AMD FreeSync-ready displays like the LG UltraWide Gaming Monitor.”
Specification:-
- AMD FreeSync Technology
- Screen Size Class (diagonal): 29"
- Panel Type: IPS
- Refresh rate: 60Hz
- Aspect Ratio: 21:9
- Resolution: 2560x1080
- Color Gamut (CIE1931): sRGB 99%
- Brightness (typical): 300 cd/m2
- Contrast Ratio(Original): 1000:1 (500,000,000:1 DCR)
- Viewing Angle (CR>10): 178/178
- Colour Depth (Num of Colours): 1.07B (8-Bit+FRC)
- Pixel Pitch (mm): 0.2325
- Surface Treatment: Anti-Glare 3H
- Connectivity: 2x HDMI, 1x DisplayPort 1.20a
- Speakers: 2x 7W Stereo
- Warranty: 2yr (On-Site with LG - 0344 847 5454)
Only £279.95 inc VAT.
ORDER NOW
Avexir Core Red Series 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Memory Kit (AVD3U24001104G-2CIR) - Red Light @ £53.99 inc VAT
Avexir Core Series is designed specifically for the extreme power users who focus on challenging the excellence in high performance gaming experience. The Core Series is developed by Avexir R&D team with 10+ years’ experience of researching in memory core technology and designed specifically for the power users and gamers who demand ultimate performance and extreme reliability gaming modules.
Avexir strictly adheres to quality standards set by JEDEC (the Joint Electron Devices Engineering Council) and ISO9001.
With 100% hand-tested extensively in multiple PC major-brand motherboard environments at its rated speed, Avexir makes sure that both stability and performance of every memory module reach the highest quality criteria.
Features:
- Black PCB
- Black/Red high performance heatspreaders
- Red LED Strobe lighting effect
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- CAS Timings: 11-11-11-24
- Dual Channel Kit: (2x4GB)
- 100% tested at 2400MHz in Intel & AMD based motherboards
- Lifetime Warranty
Was [£59.99] Inc. VAT
Only £53.99 inc VAT.
ORDER NOW
Avexir Core Red Series 16GB (2x8GB) DDR3 PC3-19200C11 2400MHz Dual Channel Memory Kit (AVD3U24001108G-2CIR) - Red Light @ £109.99 inc VAT
Features:
- Black PCB
- Dual Channel Kit: (2x8GB)
- Lifetime Warranty
Was [£119.99] Inc. VAT
Only £109.99 inc VAT.
ORDER NOW
ASUS ROG G551JM-DM197H - 15.6" FHD LED / i7-4710HQ / NVIDIA GeForce GTX860M (2G DDR5) / 8G / 750GB HDD / Multi-DVDRW / Windows 8.1 64B @ £799.99 inc VAT
The ASUS Republic of Gamers (ROG) G Series delivers powerful performance thanks to Intel® Core™ i7 processors and gaming-grade NVIDIA® GTX series graphics. Be immersed in gaming worlds through its Full HD IPS panel with 178-degree viewing angles, complemented by ASUS SonicMaster and ROG AudioWizard enhanced audio. Its efficient thermal management system works silently in the background to give you uninterrupted marathon gaming sessions.
Specification
- Display: 15.6" LED-backlit TFT LCD Display resolution: FHD 1920x1080 / 16:9
- Processor Type: Intel® Core™ i7-4710HQ Processor
- Processor Cores: 4
- Processor Clock Speed: up to 3.50GHz
- Hard Drive Supplied: 750GB *1
- Hard Drive Size: 750GB
- Hard Drive Speed: 7200RPM
- Memory Supplied: 8GB system memory
- Memory Size: 4GB *2
- Memory Type: DDR3L
- Memory Speed: 1600
- Memory Socket: 2
- Max. Memory Support: 16GB
- Operating System: Windows 8.1 (64 bit)
- Graphics Chipset: NVIDIA Geforce GTX860M 2GB
- Microphone:
- LAN: 10/100/1000 Mbps
- Wireless: 802.11bgn (Single band)
- Bluetooth: 4.0
- USB 3.0 Port(s): 4
- USB 2.0 Port(s): 0
- HDMI Port(s): 1
- VGA Port(s): 1
- Microphone Jack(s): 1
- Headphone Jack(s): 1
- LAN Port(s): 1
- Card Reader: SD, MMC
- Web Camera: HD web camera
- Keyboard: Illuminated Chiclet Keyboard
- Dimension: 38.2(W) x 25.5(D) x 1.60 ~ 3.26 (H) cm
- Product Weight (g): 2.40 KG (Without Battery) 2.70 KG (with 6 cell battery)
- Warranty: 2 Years
Was [£839.99] Inc. VAT
Only £799.99 inc VAT.
ORDER NOW
ASUS ROG G750JH-T4188H - 17.3" FHD LED / i7-4700HQ / NVIDIA GeForce GTX780M (4G DDR5) / 16G / 750GB + 256GB SSD / BD Read / Win 8.1 64B @ £959.99 inc VAT
Gorgeous gaming power
G750 is even slimmer and more gamer-centric than previous G Series notebooks, which is saying a lot. It meets your gaming needs as the ultimate weapon in any gameplay genre, making you a better gamer and a mightier ally to your teammates. Once more, the eye-catching design draws inspiration from stealth fighters, presenting an ergonomically-inclined surface for greater comfort during long gaming sessions. To better keep in touch with your co-op partners and everyone else, there's an HD camera, while a range of exclusive accessories complete your gaming experiences for more thrills at home and away.
Gaming-grade power
Enjoy desktop-level performance with a pumped 4th-generation Intel® Core™ i7-4700 processor and gaming-grade NVIDIA® GeForce® GTX 780M graphics, with ASUS TurboMaster technology for the ultimate gaming experience!
Everything you need for incredible gaming
Great gaming demands the fastest interfaces and the best displays, and G750 has been built to deliver nothing but the best. Its onboard Intel® Thunderbolt™ technology provides ultra-fast graphics and data transmission via a single connection, while the Killer Wireless-N 1202 chip delivers blazingly-fast and stable wireless networking. G750 supports next-generation 4K Ultra High Definition (4K/UDH) displays for incredible levels of detail, and with ASUS Trinity display technology you can connect up to three displays simultaneously for a truly incredible experience.
Spectacle of sound
Where many gaming notebooks treat sound as an afterthought, G750 puts it front and center. It features exclusive ASUS SonicMaster and ROG AudioWizard, designed by a dedicated team of audio engineers as a careful balance of hardware and software towards the best notebook sound. Sure, with G750 your games look their best, but they also sound fantastic. Every effect and note comes out with increased power, range, and clarity. This is more than enjoyment: as any gamer knows, sound is critical to success play, giving you the edge with sonic awareness and positioning. G750 integrates the latest design, with features specifically created for gaming and gamers.
Specification
- Display: 17.3" LED-backlit TFT LCD Display resolution: FHD 1920x1080 / 16:9
- Processor Type: Intel® Core™ i7-4700HQ Processor
- Processor Clock Speed: up to 3.40GHz
- Solid State Drive: 256GB
- Memory Supplied: 16GB system memory
- Memory Size: 8GB *2
- Memory Speed: 1866
- Memory Socket: 4
- Max. Memory Support: 32GB
- Graphics Chipset: NVIDIA Geforce GTX780M 4GB (N14E-GS)
- Microphone:
- Bluetooth: 4.0
- HDMI Port(s): 1
- VGA Port(s): 1
- LAN Port(s): 1
- Dimension: 41.0(W) x 31.8(D) x 1.80 ~ 5.00 (H) cm
- Product Weight (g): 4.00 KG (Without Battery) 4.50 KG (with 8 cell battery)
- Warranty: 2 Years
Was [£989.99] Inc. VAT
Only £959.99 inc VAT.
ORDER NOW
ASUS ROG G751JT-T7070H - 17.3" FHD LED / i7-4710HQ / Nvidia GTX970 3G / 16G / 1TB 7200 + 128G SSD / BD Read / Win 8.1 64B @ £1,299.95 inc VAT
**AC Unity FREE with this ROG Laptop**
G751 is an unbeatable gaming laptop thanks to its 4th-gen Intel® Core™ i7 processor and NVIDIA® GeForce® GTX graphics, with TurboMaster technology for stable GPU overclocking and ROG AudioWizard-enhanced audio for immersive gaming. Its intelligent dual-fan cooling system keeps everything cool even in the heat of battle, and special keys let you access Steam or share memorable gaming moments with the world!
Specification:
- LCD Cover Color & Decoration: Black
- Top Case Color & Decoration: Black
- On board processor: Intel® Core™ i7-4710HQ Processor, 2.5 GHz (6M Cache, up to 3.5 GHz)
- Operating System: Windows 8.1 (64bit)
- Office: Microsoft® Office 2013 Trial
- Chipset: Mobile Intel® HM87 Express Chipsets
- Memory Slot: 4x
- DIMM Memory: DRAM DDR3 8G *2
- Total System Memory: DRAM DDR3 8G *2
- Storage: SATA 1TB 7200RPM 2.5' HDD, SATA 128G 2.5' SSD
- Display: 17.3'//LED Back-lit//300nits//FHD 1920x1080 16:9//AG//NTSC:72%//EWV
- External video display modes: "HDMI 1.4
VGA max. 2048*1536 @85Hz refresh rate
Displayport 1.1A"
- Discrete/Share: Discrete<br>
- Video Graphics: NVIDIA GeForce GTX970M (N16E-GT)
- Video memory: GDDR5 3GB
- Video Camera: HD web camera
- Optical Drive: [SATA] 9.5"mm 6X Blu-Ray (Read)
- Built-in TV-Tuner: N/A
- FingerPrint: N/A
- Wireless: 802.11ac+Bluetooth 4.0 (Dual band) -WIDI
- 3G/4G: N/A
- LAN: 10/100 Mbps
- Card Reader: SD?MMC
- USB Port: 4x USB 3.0
- Interface: "1x Microphone-in jack
1x Headphone-out jack (S/PDIF)
1x RJ45 LAN Jack for LAN insert
1x VGA Port (D-Sub)
1x HDMI
1 x Thunderbolt"
- Audio: "Built-in speaker
Built-in array microphone
Built-in subwoofer
Sonic Master"
- Weight (Kg): "3.60 KG (Without Battery)
3.80 KG (with 8 cell battery)"
- Dimension (cm): 41.6(W) x 31.8(D) x 2.30 ~ 4.30 (H) cm
- AC Adapter: "230W AC Adapter
Output : 19.5V DC, 11.8A, 230W
Input : 100~240V AC, 50/60Hz universal"
- Battery: 88WHrs, 4S2P, 8 cell Li-ion Battery Pack
- Keyboard Type: Illuminated Chiclet Keyboard
- Keyboard Specification: ASUS 417mm keyboard with 19mm full size key pitch and integrated numeric keypad
- Antivirus and Tool Software: "30 days Office 365 Home Premium
Power2Go
Adobe Reader
McAfee Internet Security 2012
MaxxAudio"
- Security:"Intel Anti-theft
LoJack"
- Supplied Accessories: Without carry bag
- Warranty: 2yr
Was [£1399.99] Inc. VAT
Only £1,299.95 inc VAT.
ORDER NOW
Some fantastic deals guys!
Specification:-
- GPU: 2x Hawaii XT
- ROPS: 128
- Warranty: 2yr
ORDER NOW
Specification:
- Radeon R9 290X
- GPU: Hawaii XT
- ROPS: 64
- Warranty: 3yr
ORDER NOW
Specification:
- Radeon R9 290X
- GPU: Hawaii XT
- ROPS: 64
- Warranty: 3yr
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x -Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
ORDER NOW
Features:
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x8-Pin
- 600W PSU Required
- 375W TDP
- Warranty: 3yr
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
ORDER NOW
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- 500W PSU Required
- 200W TDP
- Warranty: 3yr
ORDER NOW
Specification:-
- Panel Type: IPS
ORDER NOW
Features:
- Black PCB
- Lifetime Warranty
ORDER NOW
Features:
- Black PCB
- Lifetime Warranty
ORDER NOW
Specification
- Memory Socket: 2
- Microphone:
- Bluetooth: 4.0
- HDMI Port(s): 1
- VGA Port(s): 1
- LAN Port(s): 1
- Warranty: 2 Years
ORDER NOW
Gaming-grade power
Spectacle of sound
Specification
- Memory Socket: 4
- Microphone:
- Bluetooth: 4.0
- HDMI Port(s): 1
- VGA Port(s): 1
- LAN Port(s): 1
- Warranty: 2 Years
ORDER NOW
Specification:
- Memory Slot: 4x
Displayport 1.1A"
- FingerPrint: N/A
- 3G/4G: N/A
- LAN: 10/100 Mbps
1x VGA Port (D-Sub)
1x HDMI
1 x Thunderbolt"
Built-in subwoofer
Sonic Master"
Power2Go
Adobe Reader
MaxxAudio"
LoJack"
- Warranty: 2yr
ORDER NOW
efficiency wins
