Recently bought an msi 290x twin frozr from here, slotted it in and started having fun with it, started noticing artifacts (geometric lines and brightly colored textures in shadow of mordor) figured driver conflicts and reformatted the machine but the problem remained.
I tested with furmark and occt but after hours of testing never got any errors at this point I fired of a webnote and was told to try updating the bios on my MB, I did and it seemed to have solved my problem and I could play for hours with none of the previous issues.
However I still have an issue where a section of the UI (minimap or crosshair for example) is miscoloured, distorted or has a line through it, it sometimes manifests itself in chat text also, this has occurred in both the games I currently have installed (WoT and mordor).
Testing the card in 3d benchmarks occt etc reveals no errors and I really don't think the card is at fault but I'm running out of time to return the card and I'm not really sure on what to test now.
anyone have any suggestions or ever had anything similar? I'll try to get a SS to post when it happens again but the last time it happened it never made it to my clipboard so didn't catch it.
my spec
Motherboard: Asus M4A87TD Evo AMD 870 (Socket AM3)
Motherboard Chipset: AMD 870
CPU: AMD Phenom II X6 Six Core 1055T "95W Edition" 2.80GHz (Socket AM3)
Memory: Corsair XMS3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
PSU: Antec TruePower New Modular 650W '80 Plus Bronze' Power Supply
Graphics: MSI Radeon R9 280X Gaming Edition OC 3072MB GDDR5
Graphics Driver: 14.12
Thanks!
my spec
Thanks!
