** THE WORLDS FASTEST GRAPHICS CARD: AMD 295 X2 & SUB £500 !! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
It has taken huge effort on the part of both OcUK and Sapphire to get a 295 X2 to sub £500 again, in short Sapphire had to lose $100 per card as that is how much they had to sell them to use below what we last paid to do such a price due to the GBP becoming so weak against USD over last two months. :(
So first of all a huge thank you to Sapphire for making this possible and great work by OcUK for pushing them hard for this deal:
Sapphire AMD Radeon R9 295 X2 8192MB GDDR5 PCI-Express Graphics Card @ £499.99 inc VAT
No matter what the game or the resolution you can now select the maximum settings even at 4k resolution and enjoy fluid ultimate smooth framerates in latest games such as Titanfall, Diablo 3, Watchdogs and even potential upcoming games such as GTA V and Half Life 3 should they surface.
Featuring a pair of 290X Hawaii GPU's fused onto a single PCB with an advanced PLX chip along with only requiring 2x 8-Pin power connectors.
The other major feature of the 295 X2 is its cooling solution which truly does keep the cards temperatures around 60c even after gaming for hours and it also manages to do this in more or less silence with zero throttling of the cores themselves. Making it one of the smoothest, quietest and easily most powerful graphics card on the market today. If you really crave the most powerful and have or are considering a 4k monitor for gaming then the 295 X2 is the card for you.
If your demands are truly the most powerful experience possible then these cards work great in Crossfire (4 GPU's) and you will be able to smash benchmarks to pieces and have no slow downs in games.
Specification:-
- GPU: 2x Hawaii XT
- Hybrid Liquid Cooling
- Litecoin Hash Rate: 1600-2000
- Stream Processors: 5632
- ROPS: 128
- Core Speed: 1018MHz
- Memory Speed: 5000Mhz
- Memory interface: 1024-Bit (2x 512-Bit)
- Memory capacity: 8192MB GDDR5
- PCI-Express X16 lane required
- 850W or greater PSU required with genuine 8-Pin PCI-E cables such as Silverstone 1500W
- Case capable of fitting such a long card and support for a 120mm radiator
- Dimensions: Card is 307x111x65mm and Cooler is 153x120x63mm
- Power Connectors: 2x 8-pin
- Display Outputs: 1x Dual Link DVI, 4x Mini-DisplayPort
- Warranty: 2yr
Was [£679.99] Inc. VAT
Only £499.99 inc VAT - IN STOCK NOW!!!!
ORDER NOW
This is the fastest card on the market without a doubt, with huge power and 8GB of VRAM (4GB per GPU). :)
That is quite an offer. I have two R290s in Crossfire, water cooled and it cost me more than that just to purchase the kit. Good fun setting up a dual radiator custom loop though!
1440p and a secondary 1080p screen. Mainly play eve online, Rome 2, arma 3 (cpu bound I know) assetto corsa and assorted dcs titles I dip into most new release fps games at some point and I'll probably be playing more star citizen as it gets closer to release. Currently have 2 R9 280x in crossfire but wouldn't mind dropping to a single card to reduce noise.
You'll be fine at that resolution.
