***The Vapers Lounge*** 2.0
Status
Not open for further replies.
hey guys,
so just ordered my first vaping kit. been looking at e-liquids any suggestions for which ones I need to try? ;)
Welcome aboard! WHat kit did you pick up out of interest?
Also what flavours do you think you will like; I am a fruit junky so beyond that I am not much use I'm afraid!
ordered this one to start with :)
http://www.vapeescape.co.uk/Deluxe-Vaping-Kits/Aspire-Premium/Aspire-Premium-Starter-Kit.Html
only one I know I want as I tried from a friend is called "Eisbonbon" in german, not sure about the English name, probably "Glacier something" :p
What i like not sure yet, as long as it isn't too sickly ;)
Is there a way to wick that won't run my dripper dry after 6 hits.
I drip and drive and generally 2 mins after setting off I have drained the juice. Not going to faff about and fill up whilst of the move.
Dripper is a Plume.
Nice, that will definately get you started :)
I am guessing that is a Menthol Flavour?
I highly rate juices from Vaping King. They have a lot of choice ranging from pure fruit, to menthol to desert flavours. Personal favourites are Bean Flicker, Slime, The Cockney.
Dripper is a Plume.
Think it's the nature of the beast unfortunately. I am not a dripping fan but someone might be able to help.
Without finding another RDA with a deeper juice well you might be stuck.
I hear good things about the Orchid v4 for dripper potential whilst it being a tank? Could solves your vaping whilst driving woes?
I'm thinking just smash it loads of wick and soak it but that probably won't do anything other than leak out.
Might buy a squonker.
thanks will have a look at lunch. :)
asked the mrs about it yesterday she thinks i'm talking about fox's glacier mint. there's probably a store that has those
Can you guys recommend a nice RDA that's not too expensive and easy to coil? I want something for testing flavours that I make so I don't need to fill a whole tank up.
I was looking at the Vicious Ant Prodigy but it's only a hybrid on the Phenom mech and I don't want to buy yet another mech.
So, I want a nice RDA with a 510 connection for not too much cash. Doesn't need to look the business, just be easy to use.
Cherry Menthol for the win! It tastes good no matter who made it. :)
Dripper is a Plume.
your just looking for an excuse to buy a Squonker lol,
There's one going on ABGV for cheap at the moment.. mech thou!
I use this odd zing zang method.. it gets me loads of cotton in and holds a fair amount.. with the long end of the cotton tuck it in to the bottom of the coil with the short end put it between the posts on top of the long end.
It all depends on how deep your deck is, I tend to build coils high so the air comes from the bottom :)
The big dripper is a dripper with a tank on top.. you press the drip tip and it leaks/drips juice onto the rda selection...
https://www.fasttech.com/products/3028/10009819/1866102
I'm tempted to get one myself, but the bore of the drip tip is limited by the way the item works.. it's not like I can get a chuff cap on there.. :)
Oh and don't drip and drive... If I did that I would need fog lights on the inside of the vehicle! lol
I like the tobh, it's a simple three post design with afc.. you can rock it with a standard dripper or a chuff cap, the only downside is that it doesn't work well as a single coil.
Other simple ones are the UD W plus, Mako and the tugboat. :) all three post simple drippers.
What do we think of the UD Igo-W6 V2?
Tugboat looks good. Bit pricey though.
:eek: its a 5 post dripper! rather you than me mate... lol
UD IGO-W plus is only about 12 pounds :)
for tasting juice unbridge cartos are meant to be the best way of doing it.. it's basically the carto end of a cig-alike ecig without any of the cotton or wicking.. straight coil.. you drop two/three drops into it and vape about 3 hits from it, dry burn then next juice.
I missed that. Too complicated for me. I've gone for an Igo W Plus from Cloud 9.
I've done the carto method in the past but I've always found that they seem to change the flavour when compared to vaping it in an RDA in a Subtank. I want something that's going to have the same build in it with the same wick at the same power so I get an accurate view as to how the juice tastes.
This Igo W Plus should be just the ticket. Thanks for the recommendation.
Oh yeah, I picked up an iStick 50W at the weekend. LOVE IT! It's great in the hand and the battery lasts very well indeed. I've been vaping on it at 25W all Saturday, Sunday and this morning and it's still got over 50% left in it.
Derringer has just arrived from FT (this one!).
Actually very impressed with the build quality, no machining debris etc, can't wait to get it built up and begin my 'discreet' setup.
Have bitten the bullet and actually ordered a cloupor mini from them too for only £20 delivered, half the price of a UK vendor. Here's to hoping that it won't break on me as that'll be a nightmare, but that's the risk I'm taking.
Currently vaping pinkman and double apple from a friend, gorgeous!
I keep looking at RDA's. I want to like them but I always find the vape far too hot for me. No matter what build I put in.
With that RDA being the size that it is wouldn't it be very very hot?
It's extremely hot, I have a 1.2 ohm dual coil build in mine and it gets extremely hot. I had to place a delrim drip tip on it.
To cool down a rda, I build the coils above the air flow.. :)
Yea I can just never enjoy it. I have an Igo-W and a Origen V2. Just don't use them, even after playing around on them for ages. Shame because I like the clouds.
Might get the Turbo RDA that's coming soon ;)
All my builds on RDA's are lovely and cool, 6mg juices taste hot when i vape them, but 3mg is a super cool vape.
So is it your actual RDA getting hot? or just the vapour itself tasting too hot?
Status
