|Your Nepton is just another Asetek rebrand just like Corsair, Antec Kuhler, NZXT Kraken, etc. are.
I might be wrong. (Sometimes I do screw up.)I'm pretty sure it isn't. (Either that or all the reviews are wrong)
Which AIO cooler is that gives the best performance at the most quietest sound level?
Also, is it worth water cooling your GPU? (Kraken G10)?
I might be wrong. (Sometimes I do screw up.)I know Asetek has all the patents on CLCs and made a deal with CoolIT. Maybe they did the same with Cooler Master.
I know the Nepton 240M pump moves more water than others.
Do you have any links to what is going on with these Asetek patent infringment suits? Not doubting you. Just curious to know what is happening with them.lol the only deal Asetek has with CM and CoolIT is to decide when to meet up in court. The Nepton and Seidon series from CM are their own design.
The H220X is very similar to top tier air and H240X is only slightly better ... and I don't think of top air coolers as overkill.
I've already acknowledge I was wrong.Yeah, I don't think that's true at all... not by every single review and piece of literature I've read anyway. But point me to a source that says different by all means. I'm not saying the Nepton is VASTLY superior to every other cooler on the market, but it's a very solid choice and well priced, and their pump is a custom design from what I understand. Performs very well for me anyway, I can't hear it at all, and it keeps my 4.4 OC'd 5820k at 30c idle. The NZXT X61 doesn't offer much more and it's WAYYY overpriced for what it is. Swiftech is a great choice by all means, but if you have NO plan to ever use it for anything but a CPU and only intend a small overclock, it definitely is overkill.
As to who is actually making the Nepton I don't know
