BF Hardline - AMD cards getting panned (not by much)
If its anything like BF4 I am expecting to see some stellar results from the 295x2 in Mantle mode, especially in the frame-time analysis.
I can't argue with that. I proper suck but it is good fun none the less.
I really suck at BFH right now.
Can't get used to the ttk, its really fast compared with BF4. i'm used to having that split second time to aim. i do it in BFH, even at 5 yard range i pick the gun up to aim and usually lose because my opponent just points and sprays.
I think a lot of them are from CoD and play it like CoD which works for them as its very CoD like.
I have not even fired up the MP yet :o
When I am all settled in, I look forward to some rounds with the MLG guys :)
Its not bad, i like the voice-overs, was sniping on Dust Bowl.... every kill or spot had that Martin Lawrence voice and humor... yeah its fun.
At 1440p and 4k those 4GB cards aren't too far off there limit.
Guessing next years standard will be 6GB?
Aye, I'm getting near 4GB readings using Mantle at Ultra (dropping to 2xMSAA) at 5760x1080 on single player. Not had any stutter or sign of going over my 4GB limit, but it is weird to see GPU usage getting up to 7500MB+ on Afterburner's OSD where everything else sits so much lower (I'm running 2 cards, so AB shows double my memory usage). :)
Memory must be caching to some degree, see a peak usage of 2800mb on 3gb 780's at 1440.
Is that the same vram usage for bf4? Get similar in it using DSR at 2560x1600. Cant recall what the HL beta used at that res though.
I've always set x4 msaa, but apparently there's some kind of issue where it doesn't work properly in frostbite games anyway. Remember reading about it in the bf4 thread in pc games sub forum.
VRAM usage with GTX970
