Hi Guys,
I'll try and keep this simple. It is with regards to streaming from 2x 3TB WD Mybooklive NAS to Kodi (XBMC).
My network was;
VirginMedia Superhub 2.0, located upstairs
cat5e cable directly from Superhub 2.0 leading downstairs, directly in to my Acer Revo RL70 running Kodi Helix RC on OpenELEC.
This setup works fine, I can stream MKV DTS 1080p files no issue at all. I even have caching enabled which loads well in front of what is needed.
My network is now;
cat5e cable directly from Superhub 2.0 leading downstairs, directly in to a TRENDnet TEG-S50g 5-Port Gigabit Unmanaged Metal Desktop Switch, then via Duronic CAT6a in to Acer Revo RL70 running Kodi Helix RC on OpenELEC.
This setup buffers just seconds after launching a movie. I have tried swapping ports on the switch. Removing the switch from the network and going back to my original setup works a charm.
Is there anything immediately apparent to the networking pros? I appreciate I'm using CAT6a between switch and HTPC, but as I understand it its backwards compatible.
My network was;
My network is now;
