Pentium K. whats your settings.
Permabanned
6 Feb 2010
Barnsley
Got one to test a set up and as i have it in the rig i want to see what i can get out of it.
One night only as my i5 4690k comes tomorrow.
Cooling is custom water.
So...
What sort of clocks should i be looking for
Max volts on ring and core.
Same as any haswell cpu
Vcore you will be fine upto 1.35v(could go higher) on water
Vring 1.20-1.25
Your more likely to hit your chips limits before these voltages become usefull probily.
hahaha :)
so....
5Ghz no post
4.9Ghz Post no boot
4.8Ghz post no boot
4.7Ghz and i am posting this to you right now :P
this thing fly's haha just got a 180 on cinebench
it will boot and bench at
4.7Ghz @ 1.325v any lower = BSOD
4.5Ghz @ 1.3v Playing BT4 max 52c
i got 2 chips. i kept the best one
4ghz@1v
[email protected]
[email protected]
[email protected]
[email protected]
[email protected] which is the setting i am using, but i dont use that pc very often
5ghz was meh at1.55v and was only bench stable really.
2nd cpu
[email protected]
[email protected]
[email protected]
4.7ghz was bench stable on 1.4v.
i am working on dropping vcore now.
any advice on where the uncore clock should be for 4.5Ghxz core clock
I thin i had my ring voltage all wrong, i have set it to adaptive now and my vcore is at 1.235 for 4.5Ghz(still working on dropping)
i can't remember much but i dont think the uncore or cache ratio overclocked very well on either of mine. 1:1 ratio is best, but i would think 40x or more should be ok for 4.5ghz.
right now i have.
core. 45 @ 2.225. any less is a no boot, but stable at that.
uncore. 40 @ adaptive +0.100(1.075(in HWMonitor)). not played with this just know it boot at that
the sitting hit 57c after 20 runs of intel burn test
