AMD R9 290X As Fast As Titan X in DX12 Enabled 3DMark – 33% Faster Than GTX 980
2 Jan 2012
UK.
The update to the article shows that something weird is going on right now. Take all results with a pinch of salt for now.
It explicitly states in the description of the test in the 3dmark software to not use it to compare graphics cards.
On the video from the other PC place online, they said that it wasn't good for comparing what GPU was best? Mainly to see how the CPU's were handling the multi-threading? or did i miss interpret this?
No I don't think you have, sounds about right and tallies with what I said above.
Do not compare GPUs vs each other only % increases of the same GPU with different CPUs and DX11 vs DX12 draw calls.
This is a CPU benchmark running at 1280x720 just saying :p.
Edit : it's wccftech :p they don't even test hardware they grab info from here and there.
The most impressive thing is DX12 comfortably beating Mantle, considering Microsoft are supporting more than just a single architecture you'd expect DX12 to have more overheads for the wider compatibility so it's either credit to Microsoft or shame on AMD.
