FX-8350 For Streaming? With Asus M5A78L? Or switch to Intel?
Still trying to figure out what to do with my setup. To try and cut a long story short this is my build
Corsair 500W CX Builder 80 Plus Bronze PSU
AMD FX-4300 3.8GHz Socket AM3+ 8MB
Kingston 60GB SSD
Kingston 8GB (2x4GB) DDR3 1600MHz
Toshiba 1TB
Asus M5A78L-M/USB3 AMD Socket AM3+ Motherboard
MSI HD 7750 2GB DDR3 DVI HDMI DisplayPort PCI-E Graphics Card
I have a new 240GB SSD I'm installing tomorrow
I play FFXIV and with the new expansion coming out I wanted to upgrade my graphics card and start using higher settings. But I would need a new PSU (which is a given, I'll be buying one anyway) but it would bottleneck with my CPU
So my thought now instead of buying a new PSU, card and CPU all in one go I would buy the PSU and CPU now (because my graphics are not bad by any means, and I can hopefully stream) and buy a card nearer the time.
I'm looking at the AMD FX-8350, I'm hearing it's really good for multitasking and streaming so I'm just looking for your thoughts, will I be able to stream with this CPU in my build? Compatible with my motherboard and the Sapphire R9 280X I'd like to get in the future?
Thanks in advance!
Kingston 60GB SSD
Toshiba 1TB
Thanks in advance!
