Nah, no probs bud. Nice to see that you got a decent chip after the issues with the first one.Can take a pic of it if that helps?
Nah, no probs bud. Nice to see that you got a decent chip after the issues with the first one.![]()
Probably just a bug in FS, as your score looks spot on.Yes, I'm really pleased with it but not sure why the FS benchs are showing max turbo clock as 800mhz![]()
What's the ASIC ?Yep, ASIC ratings on mine are.
card 1, 85%, 1124 boost
card 2, 74%, 1097 boost
The higher rated one is a rev2 wf model that uses dual 8 pin pcie as opposed to 1x 6 and 1x 8 on the bottom card which is the rev1 model of the wf. Slightly longer pcb on the older card too.
Expect you'll be sticking up a few bench runs soon then 8 Pack, look forward to your results.
What's the ASIC ?
Good explanation mate, in my case I look at it as one card clocks better than the other. I'm a simple guy.Its the amount of electrical of leakage or the core, the higher the Asic the less it leaks and the lower vid it needs , the lower the asic the higher the leakage and the more power it needs.
It gets a little more complicated than this but that's the long and short of it.
Cheers mucker, seems it can do FS no probs at 4.8, bf4 or crysis 3 bsods rather quickly. Still, 4.7 for daily use aint too bad.
