Archer Season 1 Blu Ray
Caporegime
18 Sep 2009
Dormanstown.
Am I missing something, or is it impossible to get Archer Season 1 Blu-ray that'll actually work with my Region 2 stuff?
I have a PS4 (UK obviously) and a Blu-ray drive in the PC (Which is limited to region 2 with Arc soft, as you can only change it so many times) and an external, again with whichever device it's attached to using arcsoft.
I'm just perplexed.
Nope, NTSC (region 1) only from what I've found when I was looking for exactly the same. It *may* be available in a boxset but I've already got 2&3 so didn't want to buy them again.
Doesn't look like it.
So am I looking at software to circumvent region restrictions?
It'd be less hassle to burn myself off a flipping season 1 Blu-ray :(
That's what I ended up doing. It ridiculous that in this modern age I'm being forced into finding it on the web because of an archaic supply system!
My mate has all but the latest and I don't think his BR player is multi region.
Indeedy he will not have a multi region one , if any manufacturer broke the rules then their player would get black listed and no new discs would ever play on it from that point onwards , thanks sony
I've been unable to find any Region B Archer Season 1, so if he's got it, he's not playing it on a UK BR player.
I've got my Ultrabook set up in Arcsoft to be Region A, I'll just use that as a Region A player, I've still got my PC and Surface 3 after all.
My Archer Season 1 Blu-ray turned up earlier.
