- 24 Dec 2007
Hi, so I've noticed recently that my H100 makes a loud noise (grinding sort of noise) at startup and at a much lower volume at idle. I've read that this is a power supply compatibility issue (which is fixed on new models) which can be fixed by running the pump from a fan controller and adjusting it's speed that way. Is this correct?
If so, would I need a 3pin to molex adapter too or would I be able to run it straight away from say, a Bitfenix Recon?
Thanks!
Thanks!
