Spec.
Intel Pentium Anniversary.
Gigabyte B85N Phoneix motherboard.
Geil Extreme 2x2gb 2133 memory.
Cooltek UMX1 plus.
Silverstone Strider 500w SFX PSU.
MSI GTX Titan Black.
Intel 320 series SSD.
350gb Laptop SSD.
OK, so some pics. First up the case.
Inside.
A GPU.
The board, sadly with orange giblets.
The CPU and cooler.
So the idea is to copy the colour scheme of the Titan Black and build a micro PC based around it.
The case will need better cooling and ventilation than it has now. So I bought one of these to cut into the side over the GPU.
Which will be painted black.
Work so far. A GPU back plate. No SLI this time so much cleaner look.
Cut.
Cover.
Test fit.
Design.
Cut and install graphics.
Please note : the Black part is missing because I had the blade set too deep. It mashed it, so I will produce it later and the next time I have the plotter out.
Parts on order and general ideas.
Two slim fans, to be fitted outside the case in its belly.
Braiding.
Treated myself to one of these..
Some Montana Black "Power Green"
Also one can of Hammerite Satin Black..
The braiding scheme.
I have two greens to choose from.
For filtering dust I chose fly screen mesh.
In silver=grey to suit the colour scheme. Whilst it's not as tightly woven as proper fan filter material it does stop larger dust bunnies and allows for very good airflow, something this build is going to need.
Updates coming soon, I'm currently working on the Mayhem fan grill that needs to be black.
